Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-11-2010, 11:32 PM   #1
JasonC3
CF Senior Member
Default heater fan blower motor - 1971
My heater fan does not work on high but it works in the other settings. I substituted my relay from my 76 - but it did the same thing. Do you think it is a bad switch or is there anything else I can test? It really does not put out much air on these lower settings.
JasonC3 is offline   Reply With Quote
Old 11-12-2010, 12:00 AM   #2
...Roger...
CF Senior Member
...Roger...'s Avatar
Check the high blow fuse.
...Roger... is offline   Reply With Quote
Old 11-12-2010, 10:31 AM   #3
JasonC3
CF Senior Member
Roger,
This certainly sounds logical but I don't recall seeing a "high blow" fuse in the panel. I will have anothoer look, though. Is it in the panel near the brake pedal, or in-line somewhere, or in another location? Thanks.
Old 11-12-2010, 10:51 AM   #4
Peterbuilt
CF Senior Member
Peterbuilt's Avatar
Default Hidden fuse.
The fan high speed fuse is in line and under the drivers fender a little foward of the master cylinder.
Peterbuilt is offline   Reply With Quote
Old 11-12-2010, 11:57 AM   #5
...Roger...
CF Senior Member
Old 11-15-2010, 09:50 PM   #6
JasonC3
CF Senior Member
Thanks much! That was it. The fuse was OK but the fuse holder was not very good. I cleaned it up and it works but I will have to make a more permanent fix.
Old 11-16-2010, 06:02 AM   #7
7T1vette
CF Senior Member
7T1vette's Avatar
If the fuse holder spring is good and the contacts are clean, you already made the 'permanent fix'. The fuse is there for a reason; don't try to 'improve' on it.
7T1vette is offline   Reply With Quote
Old 11-16-2010, 10:41 AM   #8
JasonC3
CF Senior Member
Quote:
One of the prongs is worn down so the spring wants to push the cap to the side. I just planned to change the fuse holder.
Old 11-17-2010, 06:08 PM   #9
STODD
CF Member
Does the fuse live in the same place on a 75, I have the same problem but have not found the fuse?
STODD is offline   Reply With Quote
Old 11-18-2010, 07:50 AM   #10
vetteguy75
CF Senior Member
LA Events Coordinator
Support Corvetteforum!
vetteguy75's Avatar
vetteguy75 is offline   Reply With Quote
Old 11-19-2010, 06:08 PM   #11
Bob Heine
CF Senior Member
Bob Heine's Avatar
Quote:
That's where it is on my '72. There are several red wires connected to the horn relay, which is mounted on the inner fender well right next to the master cylinder. One of the thick (10-gauge) red wires has a fuse holder six inches from the connection to the horn relay. The other side of the fuse holder is a 12-gauge orange wire.
Bob Heine is offline   Reply With Quote
Reload this Page heater fan blower motor - 1971
Tags
1971, 1974, ac, blower, c3, change, corvette, fan, fuse, heater, high, inop, location, relay, switch
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
