Need advice on sound system wiring - non traditional!
I plan to upgrade my sound system but not replace the original 8-Track head unit.
So my thoughts were that I would replace the 4x6 kick panel speakers and add 6x9's in the rear.
I would add a new four channel amp and would route the 4x6 and 6x9 speakers to this amp.
I'll then plan to attach an XM Radio and an iPod connection to the amp for the music source.
So my question is without touching the original head unit wiring, how can I wire all this up directly to the battery? I know how to wire the amp to the battery, but how about the XM Radio unit? (the ipod is simple). Since I'm not using a switched source, I assume I'll need to install an inline toggle so that I can turn the whole system on and off.
Any ideas on how to make this simple?
Thanks, that's an option. But I think I'd rather have all the wiring in the storage area and utilize a toggle versus tapping into the fuse box. Just not sure how best to manage the wiring of the XM Radio power needs in conjunction with the wiring of the amp.
I'll be in the same boat here in the next month or two.
I didn't want to disturb the look of the stock radio but will be putting fronts and 8in subs, all tied to my zune that'll pop up near the seat area.
Why don't you build a box and put everything in the back. Run two sets of wires through the console up to the front speakers. once you have the Ipod plugged in there will be plenty of cable to mount that up in the front somewhere. Doesn't XM have a remote control too?
Jim
Jim
Jim
Jim
As far as amp turn-on, I would at least run a wire from the fuse box ignition switched so you don't have to flip a switch to turn the amp on-or forget to turn it off.
All you have to do is run a line into the battery box. Attach it to the positive power lug and put a fuse or circuit breaker between battery and sound system {leave the breaker in the battery box if you want}. Also run a ground line to the negative battery terminal or to the battery ground connection on the frame..just below the battery box.
Received 3,222 Likes
Run the power from the battery through a fuse then to a Bosch relay.
To trigger the system you can use a toggle or a wire from the fuse box switched ignition- or you can do a combo-whereas you have a toggle switch that only works when the ignition is on...
