Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-12-2010, 07:58 PM   #1
78 C3 Light Corvette Blue
Acct suspended by request 19 April 2011
Default Tach is at 2500 to 3000 at 55 60 MPH ??
Is this normal ??? 78 L82 Automatic
78 C3 Light Corvette Blue is offline   Reply With Quote
Old 10-12-2010, 08:22 PM   #2
Timsride
CF Senior Member
Timsride's Avatar
It can be if You have gears around 3.55:1 in the rear.
Timsride is offline   Reply With Quote
Old 10-12-2010, 08:51 PM   #3
There is no tag to tell me the gears. I think back then the rpm's ran a bit high. I remeber a 69 Firebird being high. I don't think as high as this Vette.
Old 10-12-2010, 09:01 PM   #4
604
CF Member
604's Avatar
My 78 with 3.08 gears turns 2,400 to 2,500 at 60
604 is offline   Reply With Quote
Old 10-12-2010, 10:53 PM   #5
meinthe73
CF Senior Member
meinthe73's Avatar
Eddie Elias Salinas II
whats your tire height?
meinthe73 is offline   Reply With Quote
Old 10-12-2010, 11:23 PM   #6
255\60\15
Old 10-12-2010, 11:42 PM   #7
meinthe73
CF Senior Member
meinthe73's Avatar
Quote:
Originally Posted by 78 C3 Light Corvette Blue View Post
255\60\15
Well assuming you have a th400 with a 3rd gear of 1.1 and 27" tire.
Click the image to open in full size.
so you must have a 3.55 to a 4.11
Old 10-13-2010, 12:03 AM   #8
wombvette
CF Senior Member
wombvette's Avatar
Many 78s had 3:70 gears.
wombvette is offline   Reply With Quote
Old 10-13-2010, 12:31 AM   #9
phildawg19
CF Senior Member
Send a message via AIM to phildawg19 Send a message via Yahoo to phildawg19 Send a message via Skype™ to phildawg19
my 77s tire height is 27.4 and i was at 3000 rpm at 61 mph. and calculated it out to be 3.91 gears in mine so yours are going to be close to mine
phildawg19 is offline   Reply With Quote
Old 10-13-2010, 06:15 AM   #10
fugawi
CF Senior Member
fugawi's Avatar
my 70 with 3:70 gears tachs at 2500 @ 55 mph in high gear.. stock 27 inch tires..
fugawi is offline   Reply With Quote
Old 10-13-2010, 07:08 AM   #11
jb78L-82
CF Senior Member
jb78L-82's Avatar
With stock tire height (255/60/15 or 225/70/15) my L-82 4 speed (all stock) and 3.70 gears should turn exactly 2,860 RPM's at 60 mph which it does. At 70 MPH, my car is turning approximately 3,500 RPM. Now you know the reason so many 4 speed owners convert to 5 speeds with the overdrive. It is normal! One of these days I will do the conversion as well. Hope that helps!
jb78L-82 is offline   Reply With Quote
Old 10-13-2010, 07:36 AM   #12
73jst4fun
CF Senior Member
73jst4fun's Avatar
Quote:
sounds like 3:55 or 3:70 to me..check the numbers on the underside of the differential housing, there should be the code there...
73jst4fun is offline   Reply With Quote
Old 10-13-2010, 07:41 AM   #13
604
CF Member
604's Avatar
Were did you find that calculator? That is pretty slick!
Old 10-13-2010, 08:23 AM   #14
karol
CF Senior Member
karol's Avatar
Quote:
Standard axle ratio for a 78 L82 Auto was 3.55.
L48 standard was 3.36 for 4spd and 3.08 for auto
4spd L82's had the 3.70 as standard.
so it sounds about right.
karol is offline   Reply With Quote
Old 10-13-2010, 09:38 AM   #15
meinthe73
CF Senior Member
meinthe73's Avatar
Quote:
just google rpm calculator. i think its the first one.
Old 10-13-2010, 09:54 AM   #16
81_vette!
CF Senior Member
Default Is it possible...
I recently purchased a 1977. 4 speed manual.
5200 rpm at 65 mph. Tires are 25.7 ".
3500 rpm at 45 mph.
Note: the actual rpm tested with a meter is roughly half of what the gauge shows.
So, what is causing the rpm gauge to read so high?
81_vette! is offline   Reply With Quote
Old 10-13-2010, 10:41 AM   #17
meinthe73
CF Senior Member
meinthe73's Avatar
Those are some little tires for a c3
Old 10-13-2010, 10:55 AM   #18
81_vette!
CF Senior Member
The car is lowered - so the height of the tires needed to be appropriate.
Old 10-13-2010, 11:06 AM   #19
meinthe73
CF Senior Member
meinthe73's Avatar
Nice... I said that was a small tire because that will increase rpm. Looks good, but just my thoughts get a little bigger tire for the rear, but still looks good.
Old 10-13-2010, 07:05 PM   #20
Thanks Guys
My mechanic was wondering what kind of gears were in there? I thought it was normal. How ever I thought I would ask. Get some feed back with you that own and drive these cars.
Thanks again
I will look for the code. I have to replace a clip on one of the yokes.
Reload this Page Tach is at 2500 to 3000 at 55 60 MPH ??
Tags
1962, 1965, 1972, 1973, 2400, 2500, 3000, 3500, 55, 60, 78, corvette, mph, rpm, tachs, turns
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
