All but one spark plugs fuel-fouled?
I'm trying to fix my performance issues and ran into another question.
I pulled my spark plugs after my missfiring started up again and they were all fouled.. except one. Sparkplug #8 was clean and looked just as it should, but the rest were completely black with a huge layer of carbon (Still trying to figure out what causes me to run so rich). I tried searching for this, but am not coming up with anything.
What, if anything, would this indicate? I've never heard of just a single spark plug being fine while the rest are completely fuel fouled
Not sure if this effects anything, but I rebuilt my carb several weeks ago. My engine was rebuilt less than 10,000 miles ago, but about 10 years ago.
Swann747 (02-25-2023)
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
That's not the point. The choke is supposed to stay on for a while with a cold engine to keep it running smoothly. Change the plugs and stop the short trips as this can do more damage than foul out plugs. When the engine is not completely warmed up, condensation can form inside the engine and exhaust system and take its toll on both.
1. what engine do you have?
2. What brand and part# plug are you using?
3. What carburetor do you have?
4. When you rebuilt it did you correctly adjust the float level?
5. What spark plug gap are you using?
6. Have you checked the spark plug wire resistance?
Looks like brand new. The rest are blackened by dry soot. How would I tell if it's not firing? It does look to have a small amount of carbon on the tip of the spark plug so I think it's firing, but I imagine that would mean that that single cylinder is running lean compared to the others?
2. AC Delco CR45TS
3. Holley 650cfm 4150 4777-1
4. Yes. Plus, floats were already in decent range of the correct placement.
5. .045 is the gap I'm using
6. I have not tested resistance, but the plugs are "brand new" CarQuest plugs for, I believe, a late 80's Mustang. (I deal with parts, and I pulled these out of our old stock. Probably 8 years old)
You didn't mention how new the cap,rotor, coil and wires are or if you have checked them for arcing traces.
Couple of ways to tell if the #8 plug is not firing. Start it up for a couple of minutes and check the temp of the #8 exhaust tube compared to the others.
Take the plug wire off and see if it runs the same ( bad plug ) or if it runs worse then the plug is good.
I actually installed new plugs and one of them was dead out of the box
Similar problem
My #5 and #6 were clean, it pointed to a vacuum leak, traced it to the power booster, first tested booster to see if it held vacuum and it seemed to be ok then I plugged carb vacuum intake bypassing power booster and drove the car and it ran good, replaced the power booster and it runs good now, even burn on all plugs.
The reason I checked the plugs is because car had a bad miss, I must agree a lot of problems with our cars is the lack of driving them, Tony.
