How Can I Fix These Pistons?
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,927 Likes
I was noticing that 3 of my spark plugs would foul a little, so I pulled the pistons out of the bores to see what was going on. Do these pistons look like they can be fixed? I was thinking maybe bonding some aluminum sheet metal onto the skirts and buying some special rings of some kind to make them seal again. Should I oil the piston pins with anything special before I put them back in? What type of rings do I need with these pistons after I fix them? I’m thinking a good bead blast will clean them up, but what do I do about the ring grooves…? Will JBWeld work? The third one shown doesn't have a top ring anymore. Will it work as a single-ring piston?
After I fix them, I was thinking I should cut down on the 300-horse shot of nitrous, 32 pounds of boost and back off the timing a little. Any other suggestions? If all else fails, I'll put them on eBay as original Corvette pistons - watch for the ad.
I didn't show a forth piston, because there wasn't anything left to take a picture of. Since the piston wasn't there, the plug wasn't fouling, so it must be good. I'll just leave that bore without a piston, 'cause that seemed to work pretty good.
JB Weld and silicone sealant can do wonders on about anything. Cuzin Bubba swears by 'em.
I think I see an image of Jesus in the second pic. They will be flocking to you.I would charge maybe $1.00 a person,and you could set up a lemonade stand on the side.Setup a non-profit organization and become tax exempt. sign me up.
Received 2,878 Likes
Hi Lars,
Can a poorly re-built Q-Jet cause that?
Regards,
Alan
Regards,
Alan
Put them back in the block, wet the whole thing down with a hose and stick the whole mess in the dryer... they'll "shrink fit" themselves and be good as new!
