Loud clunking when I get on the brake pedal
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
I have LOUD clunking sound when I get on the brake pedal. Sounds like something wants to crack. If I feather the pedal it doesn't do it. Sounds and feels like its coming from the front drivers side.
I pulled the wheel and everything looked fine. The caliper looked fine, no cracks or any visible evidence of something broken. I have not yet removed the brake pads or the caliper, that's today.
Any ideas before I rip into this.
Thanx....Steve
Thanx....Steve
I had an issue where the tie rod was not installed correctly. The extra length of the bolts that snug down the ends was protruding forwards and contacting the control arm when the front end lowered during braking.
Reorienting the tie rod bolt connector thingy solved it.
Steering links, ball joints, wheel bearing....basically, any components linked with with front wheel can cause such a problem sound. There is definitely something wrong and you don't what to find out what it is by having it fail while driving.
Steve,
Could be anything. The lower aframe bracket broke on mine. Judging by the condition of your car I doubt it is anything as serious as that. If you read this before Sunday afternoon PM me. I'll stop over and hopefully two heads are better then one. One person under while the other hits the brakes usually works
My friend offered to come with me but I told her your car is too low and she should just stay home.
Steve,
Thanx....Steve
Thanx....Steve
