Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-23-2010, 07:55 PM   #1
tgensel
CF Senior Member
Default 396 with a 454 crank
Has anyone here used a 396 block with a 454 crank and 702 bb heads as I was given all these parts and was thinking of a big block c3 project.
tgensel is offline   Reply With Quote
Old 09-23-2010, 09:38 PM   #2
PuddleJumper
CF Senior Member
PuddleJumper's Avatar
Quote:
im not 100% sure but i dont think they make the pistons or rods to make it work right..
the only prob i see here is the prob with the 366 and that is to hot of cylinders..
PuddleJumper is offline   Reply With Quote
Old 09-23-2010, 11:18 PM   #3
7T1vette
CF Senior Member
7T1vette's Avatar
I think that would get you a 421 Chevy engine. Hmmm... The Pontiac folks might be miffed.
7T1vette is offline   Reply With Quote
Old 09-23-2010, 11:54 PM   #4
d555
CF Senior Member
d555's Avatar
Default Lotsa grinding required!
The con rods will hit the bottom of the bores. The 396 was never clearance'd for the 4" stroke. The 396 was internal ballanced, external on the 454. You can come up with a Piston/rod combo that will work. But why? I'd sell the the block and start with 454 block. Or you could find a 3.76" stroke crank and build a 396. Problem with 4.094 bore is the small bore will shroud the intake valve, power will be limited... but somebody is looking for that 396 block! What year is it? If its a 65 or 66 it will have a grooved cam bearing/rear cam journal. Oiling is differrent on the early Mark IV's:o
d555 is offline   Reply With Quote
Old 09-24-2010, 12:49 AM   #5
PuddleJumper
CF Senior Member
Quote:
agreed there
Old 09-24-2010, 02:11 AM   #6
HamadUP
CF Senior Member
St. Jude Donor '08
Support Corvetteforum!
HamadUP's Avatar
Can the 396 blocks be bored to 4.25 for a 427 cu displacement? .. if yes then that may be a better option.
HamadUP is offline   Reply With Quote
Old 09-24-2010, 07:09 AM   #7
ronkeira
Junior Member
Kieth Black makes a piston #361 to use for this application,434 cubes.Check the KB website they should give any info for clearence issues also.
ronkeira is offline   Reply With Quote
Old 09-24-2010, 07:43 AM   #8
L88Plus
CF Senior Member
Even if it sonic checks, there's still a ton of grinding for rod clearance.
Find someone rebuilding a muscle car and sell the block to them, then pick up a generic 454 block and build 'er.
L88Plus is offline   Reply With Quote
Old 09-24-2010, 07:58 AM   #9
midyearvette
CF Senior Member
midyearvette's Avatar
Quote:
some, not all the 396 blocks can be bored for 427 .....
what is the casting #?
midyearvette is offline   Reply With Quote
Old 09-25-2010, 09:47 AM   #10
Big Block Dave
CF Senior Member
Big Block Dave's Avatar
Building this combo would just be a waste of good money to prove that you could build this combo, when you could more easily build a bigger and simpler motor that will definitely make more power.
Big Block Dave is offline   Reply With Quote
Old 09-25-2010, 01:27 PM   #11
cm2dinger
CF Senior Member
cm2dinger's Avatar
andrew aldinger cm3dinger
Quote:
cm2dinger is offline   Reply With Quote
Old 09-27-2010, 09:55 AM   #12
tgensel
CF Senior Member
Thanks for all your help
I'll check with my engine shop to see if I can swap something and I'll get the casting #
Old 09-27-2010, 10:53 AM   #13
gkull
CF Senior Member
gkull's Avatar
That is a total NO! .060 over bore was max which is 4.154 With sonic testing some blocks went .090 over. 4.185 was the uper limit even with the blocks stamped with either Heavy duty or Super duty. The 396 were always kind of considered as garbage along with it's 402 ci bigger brother. When the 427 came out it was king and the late 60's you had around 500 ci stroker motors in racing
gkull is offline   Reply With Quote
Old 09-27-2010, 10:54 AM   #14
7T1vette
CF Senior Member
7T1vette's Avatar
Why not just build up the 396 with modern components. It will make good HP/torque and it's still a big block. But, if you want a big cubic inch motor, start with a 454 or an aftermarket BIG block.
Old 09-27-2010, 02:57 PM   #15
427Hotrod
CF Senior Member
427Hotrod's Avatar
It's an unusal combo for sure. CK Popular Hotrodding sometime over the last couple of years. They had a Nova in there with that combo with some compression that ran well. As mentioned, for the trouble it's a lot easier to build a 454...blocks don't cost that much used.
JIM
427Hotrod is offline   Reply With Quote
Old 09-27-2010, 07:33 PM   #16
Wrencher
CF Senior Member
Wrencher's Avatar
I agree with the others, swap the block for a 454. Heck, post the numbers in "for sale" and offer to swap for a decent 454 block and then you would be all set. BB are expensive enough as it is to build, you don't want to waste your cash on a morphodite like that!
Hans
__________________
The Larry Shinoda Collection: '69 L-68, '70 BOSS 302, '65 & 67 Corvair Monzas... http://www.corvetteforum.net/c3/wrencher/
In progress: '88 GTA, 425/409 2x4 (looking for a '62...)
Wrencher is offline   Reply With Quote
Old 09-27-2010, 08:05 PM   #17
Indiancreek
CF Senior Member
There are a number of them that will take a fair amount of over bore. Sonic teast is a must and the ability to off set bore will help also. If your shop can't or won't off set bore it will only be able to be bored to the min. thickness of the thinest part of the cylinder wall.
Indiancreek is offline   Reply With Quote
Old 09-27-2010, 09:11 PM   #18
tgensel
CF Senior Member
This all started since my engine shop (friend) has the block, heads and crank and basically is giving me the parts and probably the machine work as well, although I'm not the type to take something for nothing so we'll be trading labor for sure. He has been in the business for over thirty years building race engines as well as mild rebuilds but is semi retired now. He has done some strange stroker combos and said we would need custom pistons and rods. If I can find a 396 crank or a 454 block I agree that would be best. This race shop is the local drag racers hang out (I'm the youngest at 50ish) so I'll start asking around but most of these guys are blue oval guys.
Old 09-27-2010, 09:38 PM   #19
Indiancreek
CF Senior Member
If a cast 396 crank would help you, I hvae one you can have if you pay the shipping. $100 and I'll turn it for you.
Old 09-29-2010, 09:38 PM   #20
tgensel
CF Senior Member
Thanks Indian creek much appreciated! I'll see if I can find a 454 block first as it is after all about " more power"! I do however want to do a big block since in all the years I have been around cars I have never had a big block of any brand.
Reload this Page 396 with a 454 crank
Tags
361, 376, 396, 427, 454, bbc, big, block, bored, crank, engine, kb, pistons, stroke, thiry
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
