Need help on hose location 74 Corvette
Problem: Hose is going to nowhere?
Car: 1974 Corvette - 350 CI - 4 Speed
Hose is coming from: Under the washer fluid container it has a canister with two hoses. This is one of the hoses.
Help Please: Where does it go?
Looks like its coming from your charcoal canister and running up underneath your air cleaner.
My cannister had like a million hoses coming out...........I took it all out!
Paul 74
Based on the hose placement on the carb, your car is an automatic? You have an extra vac port on the upper front side of the carb.
Where did you run the distributor vac hose too?
I still need some help.
Could you post some images of your engine too?
MVMA is Motor Vehicle Manufacturers Association.
If need be I can label all those hoses for you.
8th Gear
ixlor8
Mine ia 74 automatic. I'm sorry but my car is in the middle of a resto and completely apart. I took some notes and if this hose is coming off the black can under the washer jar there is a short six inch hose that just hangs under the car and is not hooked to anything as i believe it is a vent hose. The other hose as Paul 74 said goes from this can and runs under the air cleaner and plugs into the front right side of the carb. It burns off the fumes. As one of the other postings said it probably runs even without it hooked up. Hope this helps and sorry I cant post pics.
ixlor8
The car will run with out any of that hooked up. My dad took all that off of my 73 when we went autocrossing.
