New front brakes get hot then lock up
Ok, so I finished installing all new brake components. I mean new booster, master, all the lines, proportioning valve, rebuilt the calipers. I reused the rotors and pads because they were still good. Everything else is new. I got the kit from Zip Corvette.
Finished bleeding the brakes the first time by using a vacuum gun. This worked fine on the rears but could get no fluid through the fronts with out pumping the brakes. So......had to use the old pump, hold, loosen, tighten, do all over again method on the fronts. The brakes were working fine so went on about a 10 mile drive. On the way back to the house, and after a few stop lights, noticed that something was dragging pretty bad so I pulled over. The front pads were smoking! Put the car in drive and it sits still. They were locked up. during this time noticed that the brake pedal was hard as a rock, even with no vacuum on the booster. After a little while they cooled off and I was able to drive home. Now the pedal goes all the way to the floor and the brakes hardly work..........Any ideas??????
Dragging brake pads is one thing...partially applied brakes is different [worse]. In the first instance the pads can get hot and burn on the surface, plus maybe even warp the rotors. In the latter instance, you can generate some serious heat up to catching the pads/tire on fire.
If the pads are dragging, it could be that there was zero runout on the rotor. You need a few thousandths of an inch runout to keep the pads from staying on the face of the rotor.
If the brakes are partially applying...but only on the front, then they must not be completely releasing pressure after you exercise them. That would either be due to a sticky proportional valve and/or a sticky master cylinder piston that doesn't release fully. I would lean more to the P-valve being sticky.
If the above doesn't unlock the calipers, with the master still away from the booster try loosing the front line nut on the master and see if fluid escapes under pressure. If this releases the calipers the master is holding pressure for some reason.
(Careful not spray brake fluid on your paint)
The pedal pushrod inside can also be too long but you should notice no pedal freeplay.
I would try this. Get the front wheels off the ground. Rebleed to get your pedal back. Pump pedal up and see if fronts will lock up. If they are locked loosen the 2 nuts holding the master to the booster. If this unlocks the front calipers the length of the pushrod might be not letting the master return. Try moving the master back against the booster to see if the rod is hitting before the master bottoms out. If it is the pushrod is too long.
No, the master has the correct size to match the lines coming from the proportioning valve.
Not sure why it would do it once and not a second time. Also sounds like the push rod is a little too long. Mine is not adjustable....Can I buy an adjustable one somewhere or should I just grind a little off the current one?
Before deciding the pushrod is the problem, try putting a couple washers between the master and booster. ( gently push the master up to booster and note the gap-this is the amount of washers to use) Drive the car , if the problem stays gone then work on the pushrod but if the problem comes back you might have a problem on the booster side.
I've been running into booster/master combos that are not matched.
OK, looks like it was the push rod being about 1/4" to 1/2" too long. I put three washers on each side between the master and booster and everything seems to be fine. Drove it a pretty good distance today and the calipers were still cold afterwards. I guess now I will just cut a little off the pushrod at a time until I get the right length.
Thanks to everyone for all the help!
