Found Possible Reason For No Hot Air In Re-Vacuum Hosed C3
Hi All that has contributed to my mess.
I just ripped out all of the anti freeze hoses and replaced them. I also added new Anti-freeze and the car just runs great. This is the first time that an anti freeze change with hoses, I was able to actually feel.
Now the possible culprit!!!!
On one of the heater hoses, the one that is 3/4 and goes from the intake manifold to a vacuum control and then to the heater core I think is the culprit.
When I removed this hose, I found that the line from the control to the heater core had a brown like snake inside the length of the hose and to the core. I pressure cleaned out the line inside of the core and the vacuum control.
I now have a non connected vacuum line on top of this heater vacuum control. Does anyone have a clue as to where this vacuum line goes? I (my common sense) think that this controls the hot water to the heater core and it's why I am not getting hot air to the inside of the car. Can I be right?
Jack Miller
1977 C3 L-82
As The Beatles sang "It's Getting Better All The Time"
Jack Miller
1977 C3 L-82
That is the heater shut-off valve. [And I think I tried to steer you there in your previous thread.] The small vacuum [signal] line running to the top of that valve comes from the heater control unit in the interior of the car. If the valve could not be turned ON (because the signal line was plugged up), that's why you had heat when you didn't want it.
Any thoughts?
Jack
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
here is a hose schematic... is this what you're looking for? http://willcoxcorvette.com/repairand...lp.php?hID=273
Willcox
Willcox
Former Vendor
This might be even better....
Former Vendor
I am not there right now, but can you please tell me where the heater shut off switch is?
I need to test it as I need to buy a few things from Willcox before the 31st. I want to check all of my vacuum switches.
Thanks for the diagrams, the 1st one is a winner, especially in color.
Jack
77 C3
Jack
77 C3
Former Vendor
The Water Shut off valve is located on top the inner heater box!
Willcox
Willcox
