You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
I am looking for a vacuum diagram, NOT FOR THE HEADLIGHTS, but for the engine and or emissions routing, ie distributor vacuum routing ect. I am trying to help a friend of mine. Thanks!
Your friend could use the assembly instruction manual (AIM). It shows the hose routing and color codes.
I'm sure he could.. but if anyone has atleast 1 page with vaccum info for the emissions ect. I could print off for him that would be helpful. I know I've shared many diagrams in C4/C5/C6 forums over the years... Since that is what I work on mainly, I am not really a big help to him with service info, but would like to try to help him out if possible without waiting for or paying for a manual.
Hi Rick,
Here's a photo of a base 72 engine.
1 small hose from the vapor canister to a nipple on the front of the carb.
1 large hose from the vapor canister to the pvc valve and then to a nipple on the front of the carb.
1 small hose from the distributor can to the TCS solenoid and then to a nipple on the side of the carburetor. The third port on the solenoid has a small foam filter on it.
Hope this helps!
Regards,
Alan
