1969 327 block #3956618 / Will 3.75 Crank Work?
I have a 327 that I pulled out of a 1969 impala casting no. 3956618. I would like to use it to build a 383 stroker for my bracket racer vega. I know there are mild clearance issues when using a 350 block and since the 327 used a shorter stroke than a 350 is there more material that will need to be removed or are they identical internally. Any and all info. welcome. Thanks.. cruz 86
corvald
I would think even in this market you could get $500-600 for that block. The late model roller cam blocks can be had for $200 where I live. Look at the casting date on the RH side of the rear bellhousing flange for the date code any 69 date code is worth some $$ to a Z/28 guy. Then you have to put it on Flea Bay and suffer though the auction.
