Differentail Problems while AutoX'ing
Old 07-21-2010, 01:20 PM
502Stingray
502Stingray's Avatar
Default Differentail Problems while AutoX'ing
Hey all,
Ive tried doing a bit of searching but no topics cover what Im having a problem with. Im runing my 73 Stingray at Autocross events and I just recently started running into problems that ive either never noticed or that just came up.
While going hard around turns, the yoke will walk out of the diff, causing my splines to shear and my spider to be destroyed, I have a YouTube video posted to show you exactly what I mean, watch at 1:22 and 1:42 how the yoke will walk out of the diff due to the severly changed chamber.
Now my question is, what can I do to avoid the top chamber to change that severly? Ive looked into the sharkbite systems but they dont eliminate my problem, Ive looked at a few others but they dont address the top chamber change, I already have the VBP race brace under there but it still doesnt solve the problem. I dont exactly want to put in a racing 4 link suspension that costs tons of money.
Also, I heard that some there are billet parts available for our C3 diff, like a billet yoke and billet spider gears, who sells them? I dont want to put OEM parts back into my diff, now its apart, I figured its time up upgrade, especially with my 502 in there making 600 rwhp.
Thank you for your input, sorry for the long topic
YouTube link: Watch the yoke by the pumpkin at 1:22 and at 1:42
http://www.youtube.com/watch?v=FIFZMa1pyX0
Old 07-21-2010, 01:54 PM
gkull
gkull's Avatar
Received 1,344 Likes on 1,069 Posts
I just did my rear end and I would say that you probably have one or maybe even two problems.
the stock yokes ends ware off sometimes clear past the C-clips. I bought the custom hardend yokes from Mid-America for something over $500 a pair about 12 years ago "Great investment"
Your second problem could be the posi unit its self. Especially if it is an Eaton cone type. The interior metal just wares away and you end up with yokes moving in and out.
I use www.tomsdiferentials.com posi unit and they are about $800 I also have the aluminum disks to hold the rear end cross member. I use "Smart Struts" to limit camber change during the verical travel of the rear wheels. I was using a 500 pound custom rear steel spring and just now lowered it to only 420# mono.
Old 07-21-2010, 02:05 PM
moonsteel
Holley HP EFI w/TPI
Support Corvetteforum!
moonsteel's Avatar
does the dragvette setup help at all?
Old 07-21-2010, 02:19 PM
Hauq`
Hauq`'s Avatar
Wow, that is impressive chamber change. Gkull is right on that your yolk C-clips, are broke, or warn off. When you jack up the rear of the car and grab to top of the tire and pull does it move that much. I'm a little surprised that you were able to pass tech inspection. When my axles show out of tolerance movement I'm going to fab up some upper links for a 6 link and remove the c-clips and movement all together.
Also as an observation it looks like you could use some longer spring bolts, if they don't interfere with the tires, so that your axles are parallel to the ground at rest. That way as the body roles with the turn the chamber, top of the tire, would be pulled in.
Old 07-22-2010, 12:00 AM
Jim_Harrison
Jim_Harrison's Avatar
You are mssing at least the Driver side C retaining clip. Interesting as there was a big post on this issue a few months back with some forum members insisting that that a clip missing wouldn't cause a problem.
Old 07-22-2010, 03:15 AM
Gale Banks 80'
Gale Banks 80''s Avatar
The Clip Missing guys wern't Autocrossing.....
Old 07-22-2010, 07:49 AM
texaswilkins
texaswilkins's Avatar
Best video I've seen in a long time. I had no idea the suspension moved like that. Your car also sounds pretty good.
Bill
Old 07-22-2010, 09:50 AM
crf311
crf311's Avatar
Great video. By the looks of it you may be missing the c clip as others have stated. also I would check out the bushing on the trailing arms, they may need changing. Looks like you are getting some serious tire roll, you may want to try some low profile tires. imho
Old 07-22-2010, 10:17 AM
v2racing
v2racing's Avatar
It does exactly what I and some other guys said they would do in hard corners contrary to what a couple guys were trying to prove with CAD drawings!
Great video!
Sorry your having a problem though.
Old 07-22-2010, 03:02 PM
tracdogg2
tracdogg2's Avatar
You could just replace the spiders and stub axles but this would be a good time to upgrade to Tom's KA 1350 c-clip stub axles and 30 spline spiders. Also add the oversize cross shaft. But it does require a bit of machining.
Mike
Old 07-22-2010, 03:57 PM
forvicjr
forvicjr's Avatar
Ya, I remember this one well. Wonder if any of THOSE guys will speak up now that they have been proven wrong. One even said the preload was so much,the car would slide before having enough force to pull out on those halfshafts! Think ill dig that thread up and post this thread to see what a responce I get.
Old 07-22-2010, 06:06 PM
PeteZO6
PeteZO6's Avatar
I can't offer anything to help your problem but I do want to say that is the est suspension video I've ever seen. It sure answers a lot of questions and maybe puts some bench racers back on the trailer.
Pete
Old 07-22-2010, 06:54 PM
hugie82
hugie82's Avatar
That's one way too check out a problem LOL
That video was so good, I had too watch it twice
Old 07-22-2010, 07:13 PM
pauldana
pauldana's Avatar
I feel vindicated....GREAT video
put in the c clips
Old 07-22-2010, 09:12 PM
Clams Canino
Clams Canino's Avatar
I was also on the team that siad you needed the clips. Great Vid!! I agree with the rest of them here - new hardened stubs and new clips.
I have a question? What rear spring is that? Brand and weight?
-W
Old 07-22-2010, 09:43 PM
502Stingray
Thank you all for your comments and responses! I have to say its the friendliest forum ive been on, Im also on LS1GTo.com and its a bunch of "I know it better"
Gkull thank you for the Link, that helps me alot Im gonna call him up tomorrow to find out prices on the diff, I think Im gonna buy it along with the stubs that ecklers sells http://www.ecklers.com/corvette-diff...1963-1979.html are these the ones you guys are talking about?
Mike
Hmm what is the price range of that? my total budget is about 1500 bucks
By the way, where can i get the better spiders from? I did a google search and ended up with 500 links, do you have any personal suggestions?
I did see that post, but I didnt want to get involved with the discussion
Old 07-22-2010, 09:58 PM
v2racing
v2racing's Avatar
Here is the second round of the thread that hotly addressed this issue. I didn't bother to jump back in the second one. The first was enough. The first one that the drawings were posted in got deleted suddenly back then.
http://forums.corvetteforum.com/c3-t...-rear-end.html
To Differentail Problems while AutoX'ing
Old 07-22-2010, 10:04 PM
Clams Canino
-W
Bumping the question
Old 07-22-2010, 10:38 PM
wombvette
wombvette's Avatar
It is interesting to me that it actually pulls out on the left shaft when in a RH turn. Lots of upward push in the suspension plus the inward force on the tire contact is rotating around the strut joint to pull the shaft out. It would be interesting to note how much play is in the trailing arm bushing.
Old 07-22-2010, 10:55 PM
502Stingray
Hey sorry I knew I forgot something, this is the Mono Spring I got from VBP, with the Poly Bushings, I used the 420 spring since like AutoXing
http://www.vbandp.com/C2-C3-Corvette...y-1963-77.html
Ecklers sells one aswell, a friend of mine has it in his 68 and he loves it, I took his out for a AutoX hotlap and it works just as fine as mine. When we installed it i was impressed as to how light it is compared to mine from VBP
http://www.ecklers.com/corvette-mono...1963-1978.html
Quick Reply: Differentail Problems while AutoX'ing
