Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-16-2010, 09:55 AM   #1
joez74
CF Member
joez74's Avatar
Default 1974 Fuse Box Diagram
Anyone have a picture and/or diagram of the fuse box inside the car. I am blowing the 20A fuse right below the "gauges" fuse, but on my box the name for that fuse is broke off so I don't know what it is.
joez74 is offline   Reply With Quote
Old 07-16-2010, 10:32 AM   #2
...Roger...
CF Senior Member
...Roger...'s Avatar
thats the RADIO-TCS sol fuse
how do you know when its blown-what is not working ?
...Roger... is offline   Reply With Quote
Old 07-16-2010, 12:46 PM   #3
joez74
CF Member
joez74's Avatar
Here's the story, I did a complete interior gut out and replaced everything. So I wired my aftermarked radio to a yellow wire in the dash that I tested as hot when the ignition was on, cold when off. Tested it several times with no issues, played great.
A couple of days ago I go out than turn the ignition to show a friend the radio and it has no power. I look at the fuse box and that fuse in question is fried. I disconnect the negative terminal on the battery, change the fuse, reconnect negative and instantly the fuse is fried again. I disconnected the radio wiring from that yellow wire and tried changed the fuse again, bam, same result.
So something is overloading that fuse, I just don't know what. And what is the TCS sol???
Old 07-16-2010, 03:23 PM   #4
...Roger...
CF Senior Member
TCS= transmission controlled spark=emission crap (IMO)
On that fuse is radio,TCS wiring,relay,solenoid etc,hood scoop fresh air fooler solenoid and pedal switch.
Bubba's wire cutters will clean that circuit up nicely.
edit- carb solenoid is also on that circuit.
Old 07-16-2010, 03:49 PM   #5
joez74
CF Member
joez74's Avatar
Thanks Roger!
Old 07-16-2010, 04:33 PM   #6
paul 74
Ontario, Canada
Support Corvetteforum!
paul 74's Avatar
Yes, the TCS solenoid looks like this. I have never figured out how it works so it is basement inventory. But if the Smog Police strike I will have it.
Forget the POR-15 black heat paint, everything on that #340261 1974 intake manifold is absolutely stock and emissions-compliant.
Click the image to open in full size.
paul 74 is offline   Reply With Quote
Reload this Page 1974 Fuse Box Diagram
Tags
1973, 1974, 74, block, box, c6, corvette, diagram, fuse, location, locationl, panel, radio, sol, tcs
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
