MSD install in rear compartment - anyone done it?
Holley HP EFI w/TPI
I'm planning to install an MSD 6AL in the rear compartment, has anyone else done that?
Wondering where the wires were routed.
yes
I had my mechanic do this a few years back. No problems. sorry i cant tell you how he ran the wires. But I don't think it was difficult. I work away ... so sometimes I farm out the work for more time to drive.
No reason it can't be done...it's good for keeping the box away from the heat. Mine is mounted behind the dash.
You might contact MSD and ask their techs if you might need to use a heavier gauge wire due to the distance. It make not be an issue, but I would check just to make sure.
you can pull off the right side dash, and install behind it. lots of room undr there.you can also install it under the right fender like i did five years ago with no problems. you can see it directly over the air cleaner.
I was getting ready to post a similar question, wondering where guys are installing them. I have a 75 and my coolant overflow tank is where fugawi has his mounted. I want it to be kind of accessable so I can set the rev limiter easily.
Mineis on the drivers side up against the firewall inside the fender. It's a beast to get to, I suspect someone installed it there with the front clip off. I've taken it out and put it back in a few times. If I were doing it from scratch I'd put it in the dash.
I did run my power and ground to it directly from the battery. I drilled a hole in the side of the battery compartment and went under the carpet behind the drivers seat and then along the outside of the drivers seat, behind the kick panel and up through a hole in the firewall. The hole was there so I stuck a grommet in it to seal it up and threaded the wires through. They were in almost perfect position to connect to the 6AL box mounted just above and to the outside. Sorry I don't have a picture.
Mine is in the wiper valley this is a real old pic before I cleaned that up but anyway it is still there the only thing that changes is the rev limiter goes up and up, it is at 8000 RPM now.
I don't think I would make the distance much longer than the wires MSD provides. The longer the wire the higher the voltage drop you would get. I would contact MSD before running it that far. Actually I was kind of shocked the wire they supply is so long in the first place
I have not done an install there but I'll offer an alternative solution, I installed my Digital 6 box and Blaster 2 coil in the area by the passenger side gill vent. This keeps the wires short and still easily accessibly by simply removing the gill vent, of course put the adjustment dials to the outside of the car. The photos below were shot before the coil was mounted. The MSD techs said the coil could be remote mounted 3 feet away with no issues & I didn't ask about further away. Mounting the MSD componets here frees up the dry space inside the car for things that really need it or are harder to mount. Just food for thought.
Let's us know what you do and upload some pics of the install.
Holley HP EFI w/TPI
Ok, installed it in the jack compartment, loads of room in there and I can feed the battery wires under the middle comparment easily.
The 4 wires for the MSD to and from the engine bay, fed those through the grommet that is already there and along the drivers side, up through the fire wall grommets.
Just looking for a 12v switched now.
I "think" the pink wires that are coming back there are for the anti-theft relay.
Since my anti-theft was butchered long before I got the car, I'm assuming it's safe to get the 12v from there.
Anyone know if this is a bad idea?
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,920 Likes
One thing to consider if you're installing the MSD in the passenger compartment is that the MSD is a noisy unit... you'll hear it running unless your car is real loud, even if it's on the shock mounts.
And get yourself the MSD noise suppressor to if you want to hear your stereo without a constant non varying buzz
Holley HP EFI w/TPI
I installed mine on the front inside battery compartment, ran the wires under the console and drilled a small hole to the right of the gas pedal and ran the wires through a grommet I installed. As far as noise coming from it, I have sidepipes.
Holley HP EFI w/TPI
Finished the install, in the jack compartment, ran the wires to the battery and everything else under the carpet.
Noise isn't an issue, sidepipes seem to drown out any sound the MSD makes.
I'll take some pictures on the weekend.
mounted mine in the wiper vally also. notched out where the RPM pill is. looks good, stays cool, easy to get to. car will never see rain... ooops forgot I live in washington state.
