73 with A/C wiring question
Old 05-24-2010, 07:58 AM
73jst4fun
73jst4fun's Avatar
Default 73 with A/C wiring question
Ok, replaced a while back the wiring harness/Lectric Limited, after chasing some wires, correcting some ground issues and doing some meter work and looking at some wiring diagrams/some are different, I'm not clear on the blower tie in, and I removed the A/C unit a while back. I know orange/power and black/ground go to the blower, orange is not hot using a tester, somehow the purple wire was tied in, on my blower I have three tabs to connect to, the bottom double connector are tan and green that connect to the evap/blower, but with the ignition on one of the wires is hot. I can get the blower to run with purple/hot suppling the power, but then if orange goes to the capacitor then where does it plug into?, not back to the ground as they show????
Old 05-24-2010, 11:56 AM
73jst4fun
73jst4fun's Avatar
Think I found some answers comparing a 72 assembly manual to a 73, seems with A/C you cut the orange connector off/.125 stub from the break out on the harness and use the purple/hot to power the motor, at least that's what I'm assuming, cant find anything that definately says this, so now what happens at at the capacator if your not using orange...love this 73....
Old 05-24-2010, 12:07 PM
...Roger...
...Roger...'s Avatar
Not sure what your saying exactly. Do you have a capacitor at the blower motor,if so I would guess the purple plugs into the cap and the cap goes to the blower motor.
Or when you said capacitor did you mean resistors ?
Old 05-24-2010, 05:10 PM
73jst4fun
73jst4fun's Avatar
Hi Roger, it's definitely a capacitor, I verified that on a assembly manual, ...it works/purple wire going through the capacitor to the motor as well... this adventure all started to get the wipers working, I must have a bad ground or something with the wiper, if I hook up the wiper the left front turn signal doesn't work, either does the emergency flashers, and blows the fuse, but the right turn signal works fine, with the wiper disconnected the turn signals work fine, but flashers still dont work.....just fun....
Old 05-24-2010, 05:28 PM
...Roger...
When you say hook up the wiper do you mean the 3 wire connector at the motor,the black ground lead or the 2 washer wires ?
Are you blowing the wiper fuse or turn fuse ?
Old 05-24-2010, 07:33 PM
73jst4fun
73jst4fun's Avatar
Yes, I'm hooking up all the wires/3 wire connector, ground, and the blue and yellow wire, have hadthe wiper switch exposed so I could test it with a test light, then plug the switch back to the connector and try the wipers...ok, are there two fuses?, I'm not blowing the fuse under the dash.....
Old 05-24-2010, 07:57 PM
...Roger...
I'm getting mixed up now (must be time to eat ). You said you were blowing a fuse. Maybe you mean the high speed blower fuse in the engine compartment ? We were talking about wipers,turn signals,blower and hazards they all have different fuses.
Dinner time...maybe I can focus after some Fazoli's.
Old 05-24-2010, 09:53 PM
73jst4fun
73jst4fun's Avatar
Ok, after some london broil...lol...with only the blower hooked up and working I have turn signals working, the wiper is not hooked up, the hazard switch is not working, fuse is ok. If I hook up the wiper motor, and turn on the wiper motor, the wiper motor does not work, the fuse for the hazard blows, no hazard lights, and the left turn signal does not work, however the right turn signal does work. All these fuses I'm talking about are under the dash........I'm thinking somewhere there is a ground that's bad with the wiper hooked up....but blowing the hazard fuse and not having hazard lights? and having only the left side turn signal not work?.....
Old 05-24-2010, 10:47 PM
...Roger...
I'm sitting here going over a wiring diagram. I really don't think you have just 1 problem. You seem to be crossing circuits. The turn signals and hazards can be a problem in the turn signal switch. The hazard fuse blowing when the wipers are turned on is what is puzzling. Its not uncommon for the wiper motor to have lost its ground and then try back grounding through the blower motor AC wiring.
The wiper and blower ground is a black 14 that comes up from the starter wiring loom. The black 14 should go on 1 of the starter mounting bolts or 1 of the bellhousing bolts BUT on occasion because the eye on the wire is so large it gets put on the pos post of the starter solenoid,this makes the case of the wiper HOT and can do all kinds of funny things.
Old 05-25-2010, 06:09 AM
73jst4fun
73jst4fun's Avatar
yes, Roger, I found that problem before while tracing the wires Sunday, and with putting in a new engine recently, with such a big eye I and others assumed that it belonged on the solenoid. I removed it and have a good ground on the scattershield now.
Old 05-25-2010, 07:20 AM
...Roger...
Very common mistake with starter replacements and engine installs.
I have seen varying damage from that mistake , no damage to frying an entire harness.
Not sure if your problem is fixed or not , if not since the engaging of the wiper motor is blowing the fuse I would try to run a temporary ground from the wiper motor to the neg term of the battery.
Make sure the 14 black at the scattersheild is in fact grounding through to the neg terminal of the battery, remember the ground cable that jumpers the passenger side motor mount is crucial for a solid chassis to engine ground. (The ground path is as follows ... neg term battery to neg battery cable to frame connection under battery through the frame to the jumper ground cable at the passenger motor mount through the cable over and around the rubber motor mount to the engine block to the 14 black you grounded at the scattersheild.)
Old 05-25-2010, 07:34 AM
73jst4fun
73jst4fun's Avatar
Thanks Roger, I'm going to pull the wiper motor and do a check on it as well to see if works ok, then I'll check all the grounds again, still puzzled on the hazard switch not working...also ground related I bet....
Old 05-25-2010, 09:13 AM
noonie
noonie's Avatar
Check the pics in this post. The soldered junction can be iffy sometimes. You may want to ring out all the grounds separately to test. If you get into the harness and resolder, I would increase the ground wire size and solder all crimps, especially the one for the blower.
http://forums.corvetteforum.com/1573717874-post13.html
Also check the ground at the alternator and the drivers side core support sheet metal screw for the lighting (hazards)
Old 05-25-2010, 10:12 AM
...Roger...
But I am suspect of the 14 ground that was hooked up to the battery positive possibly burning into adjacent wires creating cross circuits.
I think you might be best to unhook the wiring going to the starter including the 14 ground and using an ohm meter to see if the 14 black is fused with another wire.
Old 05-25-2010, 11:03 AM
73jst4fun
73jst4fun's Avatar
All good suggestions, I'll start testing the wires.....after I get some yard work and some painting done....
Old 05-25-2010, 11:20 AM
noonie
noonie's Avatar
The pic in the link shows a wire that was melted to another.
Disconnect all the grounds, test for voltage with different items on, then test the ground wires individually for continuity.
If I were keeping the car, I would redo the engine harness anyway, with bigger grounds soldered.
Old 05-25-2010, 02:44 PM
dembo
dembo's Avatar
Hello,
I don't know if it's still relevant, but I looked at the wiring & aim of my 74. In the aim there is a special page for AC optioned cars, where it says the orange wire + connector needs to be cut off. It's indeed the purple one going to the blower motor. The AC wiring harness ground plugs on the other pin on the blower motor casing, the other plug fits into the engine harness (& then going to the ground points as described by Roger)
If you want I'll scan the aim page and take some pictures tomorrow?
Regards,
Nick
Old 05-25-2010, 03:06 PM
73jst4fun
73jst4fun's Avatar
Originally Posted by dembo
Hello,
Regards,
Nick
Thanks Nick, but I have that page/sheet 60, page 118 from both a 72 and 73 manuals here...
Roger, Wilcox Corvettes has a page on testing the wiper motor for a 73, pulled the motor and it works fine at high and low speed so that's a relief...
Old 08-02-2010, 08:13 PM
...Roger...
How did this come out ?
To 73 with A/C wiring question
Quick Reply: 73 with A/C wiring question
