What has my machine shop done to me.
I have a 82 that im redoing from ground up, and have decided to go with a TPI conversion on the engine. I modified the fuel rail and asked the machine shop to turn down a fitting that would then insert in fuel rail that would have a 3/8 fitting for the fuel line connection...
What i received ive just found out....after installing the tpi unit is something that is not 3/8...3/8 is too large and its not 5/16...5/16 is too small. any suggestions?? what could it be?
the fitting look like this. Im at a loss
3/8 SAE is larger than 3/8(-6) JIC (AN), they look similar, but the SAE has a 45 deg flare and the JIC or AN as car guys call it has 37 deg flare. All other size SAE and AN (JIC) have the same thread size except -6.
little research im guessing this may be what I need.
http://www.jegs.com/p/JEGS/JEGS-Hard...56885/10002/-1
I need to connect this fitting, to the original fuel line on the car...3/8 in size.
Connect to 3/8 steel line like carb fuel line? That type fitting is called inverted flare. I thought you were using braided hose
Ok, looked at the JEG's fitting, that one uses compression style on the steel line and AN on the other, that should work.
braided line...nope, but that might be an option.
I just need to get that fitting somehow attached to the original line down near the engine mount. I was planning on bending a hard line and ferrule it together, but im up to any option.
Rick B.
If you have a local hydraulic line shop you could also get a SS braide line with the correct JIC fitting crimmed on. JIC does fit AN , you will use less fittings this way
