Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-16-2010, 07:36 PM   #1
Aussie79
CF Senior Member
Aussie79's Avatar
Default How do you remove the receiver/dryer bottle from a 79?
Hi, I have a new receiver dryer for the 79 as I have retro fitted everything needed for a R12 to 134 upgrade, the last thing left to do is replace the dryer, it's jammed in behind the fan box and the header tank from the radiator, how do you remove it?
Thanks, Dennis.
Aussie79 is offline   Reply With Quote
Old 06-16-2010, 11:58 PM   #2
blckslvr79
CF Senior Member
blckslvr79's Avatar
Remove the pan/rock shield below it, between the wheel well and the fire wall.
3 or 4 bolts and the pan drops out the bottom of the car.
You can then reach the dryer from under the car.
Or you can pull the heater box.
If you have side mount exhaust, the passenger header must be removed.
__________________
'79 L-82, close ratio 4-speed, 3:70, moderate built 350, Light Pewter Metallic w/ Oyster & Black interior, custom Alpine & Infinity stereo, chrome Hookers, STS baffles, Steelshields, VBP 360# composite spring, VBP adjustable strut rods w/heims, Ecklers High Rise hood, '74 rear bumper cover, shaved front bumper, C6 18x8.5 & 19x10 rims, 245/45/18 and 275/40/19 Potenza S04's ...
blckslvr79 is offline   Reply With Quote
Old 06-17-2010, 08:33 AM   #3
08vycpe
CF Senior Member
blckslvr79 is correct. There is an access panel that needs to be removed under the car. Two of the bolts are accessed at the bottom of the wheel well aft of the tire. The other two bolts can be accessed by removing the front two screws of the rocker molding. There is also a metal band around one of the pipes that is held in place with one screw.
Once the pipes and that metal band are removed you can lower the dryer enough to get the flexible hoses off from underneath. Then it drops out the bottom.
08vycpe is offline   Reply With Quote
Reload this Page How do you remove the receiver/dryer bottle from a 79?
Tags
1979, 79, ac, bottle, c3, corvette, drier, dryer, dyrer, heater, heating, mount, receiver, reciever, remove, vett
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
