AC Question
AC Question
If I go with a sanden 508 compressor, other than the hoses is there something else I need to cahnge? Also where is a good place to get the brackets.
this is on a 1973 with a small block.
One trick is being sure the new brackets you will need keep the compressor low enough to avoid interference with your hood. You might want to give Vintage Air a call. I installed their SureFit GenIV system in my big-block '73 and it works great! I spent less on that entire kit (installed it myself) than I had over several years in trying to get all the factory stuff to work...
