Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-22-2010, 12:33 PM   #1
tyler77
CF Senior Member
tyler77's Avatar
Default 180* out on timing, whats the best fix?
Any ideas without pulling the engine apart. Thanks
tyler77 is offline   Reply With Quote
Old 05-22-2010, 12:40 PM   #2
73StreetRace
CF Senior Member
73StreetRace's Avatar
Do you mean camshaft timing or ignition timing ?
Camshaft timing 180° out : You'll have to remove damper, water pump, timing cover.
Ignition timing 180° out : Only remove the distributor, turn the bottom gear 180°, put it back in place.
73StreetRace is offline   Reply With Quote
Old 05-22-2010, 12:45 PM   #3
mikejpss
CF Senior Member
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
mikejpss's Avatar
cant get any more simplier than that.
what makes u think its 180* out?
mikejpss is offline   Reply With Quote
Old 05-22-2010, 12:51 PM   #4
tyler77
CF Senior Member
tyler77's Avatar
73StreetRace if I turn the distribtor 180* dose that change the position of the #1 cylinder
Old 05-22-2010, 12:57 PM   #5
73StreetRace
CF Senior Member
Quote:
I suppose you were firing N°6 instead of N°1, so if you turn the distributor gear by 180° you will fire the right cylinder.
You don't have to change any spark plug wire position.
Just adjust timing with a stroboscopic light after that.
Set it at 36° total timing. See Lars papers.
Old 05-22-2010, 12:58 PM   #6
tyler77
CF Senior Member
tyler77's Avatar
Mikejpss I put a compression tester on the #1 cylinder and dial back timing light, I can just see the timing mark at atdc side just above the water pump bolt.
Old 05-22-2010, 01:00 PM   #7
tyler77
CF Senior Member
tyler77's Avatar
I'll give that a try thanks 73StreetRace
Old 05-22-2010, 01:05 PM   #8
73StreetRace
CF Senior Member
If you want to be sure that your distributor timing is correctly set, remove cylinder #1 spark plug.
Then have some someone put his finger on the #1 spark plug hole while you slowly crank the engine.
When he feels pressure under his finger, it means that cylinder N°1 is on compression stroke.
Keep cranking the engine until the timing pointer reaches TDC on the harmonic damper.
Now remove the distributor cap and look at your distributor rotor : it should be exactly in front of cylinder #1 ignition wire.
Old 05-22-2010, 03:11 PM   #9
Tom1701
CF Member
Tom1701's Avatar
Perfect instructions 73StreeRace. But what should he do from the safety side before doing this in case it starts up? I have always left the cap off.
Tom1701
Tom1701 is offline   Reply With Quote
Old 05-22-2010, 04:40 PM   #10
JMS71VETTE
CF Senior Member
JMS71VETTE's Avatar
Quote:
Tom1701
Wouldn't you just pull the coil wire to prevent it from firing?
JMS71VETTE is offline   Reply With Quote
Old 05-22-2010, 07:46 PM   #11
Ironcross
CF Senior Member
Ironcross's Avatar
you don't turn the distributor 180, rotate the shaft.....a easier fix is to change the wires in the cap 180 degrees...but the purists have to look for #1 on the cap whether its right or wrong....its OK, as long as its firing on the correct cylinder....
Ironcross is offline   Reply With Quote
Old 05-22-2010, 08:37 PM   #12
Gordonm
CF Senior Member
Gordonm's Avatar
Quote:
That is what most do not understand. It makes no difference how the distributer is installed. As long as the wires are on the correct terminals and the right location for how the distributer is installed it will fire correctly. If it is out 180 just install the wires 180 out and it will work. Now it should be installed with the vacuum advance pointing to the passenger side and you want the tach cable pointing in the right direction if you have a tach cable.
Gordonm is offline   Reply With Quote
Old 05-22-2010, 10:47 PM   #13
tyler77
CF Senior Member
tyler77's Avatar
I pulled the distributer rotated 180* and all it would do is backfire through the carb. I then rotated it back 180* with the cap still off the distributer put the compression tester back in the # 1 cylinder bumped the key untill I got compression, the rotor was pointing to the correct # 1 post. I locked the distributer down put cap back on and started it up. Fired right up I put the timing light on it and again I do not see the timing mark. I have no idea what the timing is, base or all in. Any other thoughs on this. thanks
Old 05-22-2010, 11:13 PM   #14
MrForce
CF Senior Member
St. Jude Donor '11
MrForce's Avatar
Send a message via AIM to MrForce
What started this problem?
MrForce is online now   Reply With Quote
Old 05-22-2010, 11:40 PM   #15
tyler77
CF Senior Member
tyler77's Avatar
cam shaft install all went well fired right up for brake in at 2000 rpm for 20 minutes. I put a timing light on it durning brake in, @ 2000 rpm right on the 0 mark.
Old 05-23-2010, 01:20 AM   #16
73StreetRace
CF Senior Member
You could buy a timing tape, or just make one and paste it on your damper :
http://www.summitracing.com/search/P...keyword=timing
Just buy the one corresponding to your damper diameter.
With the stroboscopic light on it, when you blip the throttle, you should see the timing tape moving. This will tell you where you are exactly.
Then rotate slightly the distributor CCW to increase initial timing and CW to decrease it.
12° - 16° initial is a good starting point for a performance engine.
When initial is in the ball park, adjust what is really important : Total timing ( w/o vacuum advance ) 36° +/- 2°
Old 05-23-2010, 02:22 AM   #17
73StreetRace
CF Senior Member
Just another thing I was thinking about :
If you changed the camshaft, did you check that the 0° mark on the harmonic damper is still indicating the real piston TDC ?
You can check it easily with the help of a piston stop :
http://www.summitracing.com/parts/SUM-900189/
This could explain why you can't see the timing mark. First check it before you attempt to set ignition timing.
Old 05-23-2010, 08:53 AM   #18
Eddie 70
CF Senior Member
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
Support Corvetteforum!
Eddie 70's Avatar
I wonder if the balancer may have slipped on him.
Eddie 70 is offline   Reply With Quote
Old 05-23-2010, 05:23 PM   #19
tyler77
CF Senior Member
tyler77's Avatar
Eddie 70 you nailed it right on the head. where they pressed the balancer togather, that is where it slipped. That is why its running good timing is still correct I just don't no what it is. I'll put a degreed tape on the balancer to try an get a good Idea what the timing is now but it could slip again. Thank you to everyone with your Ideas on how to help. Great forum.
Old 05-23-2010, 06:08 PM   #20
Gordonm
CF Senior Member
Gordonm's Avatar
If it has slipped it is time NOW for a new balancer. They have been known to slip right off and cause damage. If you are sure it has slipped get a new one and install it.
Reload this Page 180* out on timing, whats the best fix?
Tags
180, 73, 77, adjustment, c3, corvette, distributor, engine, fix, ignition, remove, set, sound, timing, timming, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
