Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-19-2010, 08:20 PM   #1
mxscooter
CF Senior Member
mxscooter's Avatar
Default hydroboost schematic?
Hi everyone,
I used to have a diagram of the hydroboost install, and have turned my place upside down trying to find it with no luck. Does anyone have a diagram? Stock '81 steering, no rack and pinion or anything. Need to know which lines go where, where the t-fitting goes, and length of hoses.
I had months of printouts of pics and posts etc and had them bound even, and now I can't find it for the life of me
Any help would be great,
Thanks!
Jeff
mxscooter is offline   Reply With Quote
Old 05-19-2010, 09:21 PM   #2
'75
CF Senior Member
'75's Avatar
I am not the author of this pic and can't remember where I got it, hope it helps.
http://corvettec3.ca/hydro.htm
Click the image to open in full size.
'75 is offline   Reply With Quote
Old 05-20-2010, 12:06 PM   #3
mxscooter
CF Senior Member
mxscooter's Avatar
Thanks, that's helpful - anyone know where the t-fitting goes, and approximately how long all the hoses are?
Old 05-20-2010, 12:24 PM   #4
DRIVESHAFT
CF Senior Member
DRIVESHAFT's Avatar
Here are a few pics for you.
Click the image to open in full size.Click the image to open in full size.
DRIVESHAFT is online now   Reply With Quote
Old 05-20-2010, 12:51 PM   #5
mxscooter
CF Senior Member
mxscooter's Avatar
Thanks, that's actually some of the original info I had lost
One more question: The hydroboost unit I have doesn't have threads on the shaft (for attaching the clevis pin to the brake pedal), instead it is smooth with a large tab on the end, and a hole in that tab. Can the tab be cut off, and the shaft threaded? If so, what size should I make the threads?
Old 05-20-2010, 01:24 PM   #6
Bob Heine
CF Senior Member
Support Corvetteforum!
Bob Heine's Avatar
Quote:
I'm in the process of putting a system in and am at the trial fitting stage.
Te return lines are not under much pressure so my setup is overkill. The t-fitting can go close to the return pipe on the back of the power steering pump. Here is the return line setup on mine (high pressure fitting for pump is arriving today):
I added a filter to the system (dirt really messes up hydraulics systems) and routed all three lines along the inner fender:
I ordered 10 feet of teflon-lined braided stainless line but I have about 3-feet leftover. Eight feet of high-pressure hose would do an entire install, even without a filter.
Bob Heine is offline   Reply With Quote
Old 05-20-2010, 03:08 PM   #7
RobRace10
CF Senior Member
RobRace10's Avatar
Some info here on Hydraboost install
http://www.corvettengineering.com/docs/HydroBoost.html
RobRace10 is offline   Reply With Quote
Old 05-20-2010, 05:31 PM   #8
mxscooter
CF Senior Member
mxscooter's Avatar
Great info, much appreciated. Any thoughts on threading the shaft, or can it be replaced?
Old 05-20-2010, 06:18 PM   #9
'75
CF Senior Member
'75's Avatar
I threaded mine 3/8-24 which is fine thread
Old 05-20-2010, 06:36 PM   #10
mxscooter
CF Senior Member
mxscooter's Avatar
quote: I threaded mine 3/8-24 which is fine thread
Thanks!
Did you remove it and if so how?
Old 05-20-2010, 06:38 PM   #11
'75
CF Senior Member
'75's Avatar
I cut off the eye end and threaded the remaining rod without detaching it from the booster.
Old 05-20-2010, 07:55 PM   #12
Bob Heine
CF Senior Member
Bob Heine's Avatar
I talked to someone at Tallon Hydraulics and he advised the same thing. You don't want to try to yank that rod out of its staked hole so just cutting and threading the shaft is fine. I'd recommend a nut on the shaft as well so you can lock the clevis in the correct position.
Old 05-20-2010, 08:21 PM   #13
mxscooter
CF Senior Member
mxscooter's Avatar
Good advice thanks
Old 05-21-2010, 12:29 AM   #14
68 NJConv 454
CF Senior Member
68 NJConv 454's Avatar
Send a message via AIM to 68 NJConv 454
Quote:
The first diagram was mine from my install.
Bob, I would advise against installing the filter in the line.
That will cause backpressure which may have an effect on the brake pedal. You may find the pedal not returning to its upright position as fast as it should.
They system is a loop, the filter will slow the return to the pump which will back up the entire loop. I'd be careful. All that info I read and guys i spoke to when doing my install were against filters or anything else that would restrict flow...even the T fitting restricts flow slightly which is why I added a second return on my power steering pump. A "Y" fitting might be better than a "T" fitting.
Since you have the filter already installed give it a shot, but don't take it out on the highway right away until you're sure the system is working the way you need it to for safety. Otherwise Hydro is awsome!
68 NJConv 454 is offline   Reply With Quote
Old 05-21-2010, 09:09 AM   #15
Bob Heine
CF Senior Member
Bob Heine's Avatar
68,
I appreciate the recommendation. This is the first hydroboost install I致e done and I知 trying not to screw it up (brakes are not an accessory!). I put the filter in because most hydraulic systems seem to have them (transmission, for example). With a tic under $2,000 invested in Steeroids and Hydroboost hardware, the filter seemed like cheap insurance. I thought the 12-gallon per minute flow (at 3000 psi) on this filter would be adequate. I read that the power steering pump puts out around 3 GPM at around 850 psi (constant pressure and flow from 900 RPM up).
I知 not crazy about the T-fitting (or the tube) so I知 going to put a couple of -6 bulkhead fittings in the pump reservoir. I知 going to try the system with the filter in place and if there痴 any kind of problem, I値l open the housing and take out the bronze element (then it値l just be another accumulator). If that fixes the problem, I値l make another line. In any case, all this work is just so I can move the car from the garage to the driveway and back while I知 prepping the body for paint and then putting in the new interior. It痴 gonna be a while before it goes on the highway.
Old 05-23-2010, 09:54 PM   #16
Bob Heine
CF Senior Member
Bob Heine's Avatar
Having decided to add two return ports on the power steering pump, I decided to rebuild the pump while I had it apart. Page 9-8 in the 1972 Chevrolet Overhaul Manual has an interesting exploded view of the pump. Items 6 and 7 in the diagram show a filter unique to the Corvette pump. There was none in my pump but perhaps the Delco rebuild kit will include one. Once I opened it up, the reservoir had a coating of dark gray/black particles, very much like what I've found in the transmission pan when I change that filter.
Old 05-23-2010, 10:35 PM   #17
pauldana
Baby...SoCalStingrays.com
pauldana's Avatar
putting mine in next week... i will need this thread...thx!!!
pauldana is offline   Reply With Quote
Old 05-24-2010, 12:35 AM   #18
MN-Brent
CF Senior Member
MN-Brent's Avatar
Great hydroboost thread.
When you get yours, be sure to measure the old power booster clevis distance and thread your HB unit up the same or slightly closer (1/2 inch) to the HB unit. Hydratech was recommending a slightly reduced pedal height as installed so you don't feel-think your pedal is too high, since it wont move as much towards the floor as it used to, which is a good thing!!
MN-Brent is online now   Reply With Quote
Old 05-24-2010, 08:55 AM   #19
Jim Shea
CF Senior Member
Jim Shea's Avatar
If you are going to braze a second return line spout on the pump reservoir, it is quite important that you locate the second spout in the correct location.
The spout shown at the 8 o'clock location can also be located just around the corner on the side of the reservoir. (Just not too far forward where it might interfere with the seal or the pump casting. Also make sure that a side spout location will not interfere with pump mounting brackets.)
Also, be sure NOT to use ordinary solder to afix the spout. The melt point of solder is too low and the spout could fall off at a critical time. You want to silver solder or copper braze the spout.
Jim
Jim Shea is offline   Reply With Quote
Old 05-24-2010, 07:50 PM   #20
Bob Heine
CF Senior Member
Bob Heine's Avatar
Jim
Jim,
I'm probably headed for disaster (my usual destination) but I'm not sure those are viable options for the bungs I want to add to my Mark V8 pump housing (this is all going into a big block car).
The 8 o'clock position is too small for the -6AN bung, which looks like about 5/8-inch diameter. The sides of the housing might fit the bung but there isn't room for a 90-degree fitting (the upper A-arm is too close on the outside and the idler tension pulley is too close on the inside).
It looks like there is room in the central recess of the reservoir for two bungs. Is there some reason the normal return area can't handle the fluid from two return lines? It looks like the chamber would dampen any turbulence from the return fluid. and the two relief areas seem pretty large.
Reload this Page hydroboost schematic?
Tags
454, boost, c3, chevy, corvette, diagram, exploded, hydraulic, hydro, hydroboost, installation, pump, reservoir, schematic, system, view
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
