Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-12-2010, 10:16 AM   #1
amf133
CF Senior Member
Default how to remove all emissions on a 1981 corvette.
I want to remove all of my emissions on my 1981 corvette. Iím replacing the exhaust with duel exhaust no cats, but want to remove all of the stuff from the engine bay to clean it up and make it look a lot better. Does any one know what stuff has to be removed and what needs to be done so there is not check engine light on? Are there any pictures online or has anyone already done the job and documented it for later? Please help.
Thank You
amf133
amf133 is offline   Reply With Quote
Old 05-12-2010, 11:03 AM   #2
7T1vette
CF Senior Member
7T1vette's Avatar
There is another thread on this same Forum by "Tnshark" wanting to do the exact same thing. Check out his thread and I will make the same offer to you if he decides not to take me up on the "parts swap".
7T1vette
7T1vette is offline   Reply With Quote
Old 05-12-2010, 12:27 PM   #3
palazzopl
CF Senior Member
palazzopl's Avatar
I did my 81, replaced the carb and minifold with a edelbrock set up. the other problem you might have when disconect the computer and harness is the lock up solinoid. I put a switch grounding the test lead under the consol near the ash tray. I only switch it on on the highway. As for the light I took out the blub.
palazzopl is offline   Reply With Quote
Old 05-12-2010, 01:16 PM   #4
MotorHead
CF Senior Member
MotorHead's Avatar
Location: Never argue with Morons. If you do, you'll lower yourself to their standards, and they'll win, based on experience !!!
Go down to you local department of motor vehicles or Drive Clean Center and they will tell you what and where all the pollution stuff is
http://www.drivecleanpa.state.pa.us/
__________________
1980 Corvette, 427ci Motown SBC 465RWHP N/A so far,500 is the goal, AFR 227 Eliminators
T&D Shaft Rockers,Vic Jr, XR286R solid roller,248/254 dur .640" lift 10.6:1 Mahle pistons
Eagle stroker rods, 4 in. Callies DragonSlayer crank, 825 Drag Race Demon, 3 in exhaust
Paint by Dream Car Garage......................................My'70 CUDALotsa ladies and lotsa trouble
MotorHead is offline   Reply With Quote
Old 05-12-2010, 07:00 PM   #5
amf133
CF Senior Member
Is it possible to just take off a few hoses and the smog pump so the engine bay looks better or do I have to take everything or nothing out?
Old 05-12-2010, 07:10 PM   #6
MotorHead
CF Senior Member
MotorHead's Avatar
Quote:
Depends on how strict they are in your area, visual inspection every year or two you can forget about taking anything off
Old 05-12-2010, 09:52 PM   #7
terry82
CF Senior Member
you can take the pump off .and plug the hoses.your egr can be blocked off .all these can be done with out having a problem and it can all be put back on .save all of it .
terry82 is offline   Reply With Quote
Old 05-12-2010, 10:11 PM   #8
amf133
CF Senior Member
If I do this will I have a check engine light on or will everything be fine?
Old 05-13-2010, 09:47 AM   #9
terry82
CF Senior Member
you should not have a problem.most cel come on when you have a problem with the 02 sensor or the tps.if you are still worried about the light ,take off one thing at a time .
Old 05-13-2010, 03:37 PM   #10
spedaleden
CF Senior Member
spedaleden's Avatar
I removed mine, just remember that there is a green wire in the ecu harness. This wire is the turn on for the AC compressor, you will need to run a new wire or pull the old one out, if your AC still works.
Without it you'll have no AC
FYI
Dennis
spedaleden is offline   Reply With Quote
Old 05-14-2010, 12:26 AM   #11
amf133
CF Senior Member
Thanks for the tips, I appreciate it!
Old 05-14-2010, 04:24 AM   #12
Tnshark
Junior Member
FYI
Dennis
Where do you run the green wire?
Tnshark is offline   Reply With Quote
Reload this Page how to remove all emissions on a 1981 corvette.
Tags
1980, 1981, 1982, 81, corvette, emission, emissions, make, motor, performance, pump, removal, remove, run, smog, swap
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
