18 in wheels on a 78
I have found a set of wheels for my 78. I want to put 18 in the rear and 16 up front. I want to fit 9in wide in the rear and 7in wide up front. I am sure that 18x9 will fit but I am not sure the back spacing. I dont want to change the trailing arms or anything like that so if I cant fit 9's then I will have to go with 8's.
Adam
Adam
Adam
Adam
Why do you want to go with 16s and 18s? 17s and 18s work but 16s really limit tire choises. You have to think about sidewall profiles also. You don't want more sidewall in the front than the rear. There are cars here running 17x8s with 4" backspace and a 245/45 tire in the front and a 18x9.5 with a 5" backspace in the rear with a 275/40 tire. If you are going to go with a 9" wheel you can still use the 5" backspace or even 4.75" if you want. If you error slightly on backspace it's always better to error on the side of a little too much since you can always "adjust" with a small spacer. Do a search using "17s" and then another using "18s". There is LOTS of reading on this.
Just keep in mind by going with a shorter (16") overall diameter front tire to make the car look lower you have to go 2" shorter in diameter to lower the front 1". The real negative to that is while the front end is lower the gap between the top of the tire and fender gets larger and is definitely not the look you're after.
Do 17s and 19s. 16s are too small to make the staggered look, look cool. You need a similar profile on each tire to make it look not stupid, and to get enough ride height in the front you can't have a low pro tire, but you'll need one in the back with the bigger rims.
I fit 19x19.5 in the back. You can go about 3/4 further back I think it was, so if you only want 9" wide rims, get some 1/2 further back to fill out the wheel well a little bit. Being, 4 1/2 of backspacing.
I too was looking for more of a staggered look on my 78 since all the 78/79's have a tendency to squat in the rear. I achieved this appearance by using 17 inch SLP rims (they are made for the C3 and require no modifications at all) by running 255/45/17 ZR tires in the front combined with new Midamerica replacement 550 coils that are 1 inch lower than stock springs and 255/50/17 ZR tires in the rear (this size preserves the rear end gear ratio of 3.70, a smaller tire in the rear would numerically raise the rear end ratio which I did not want to do) which are the same overall diameter as the OEM 255/60/15 tires. The difference in diameter between the 255/45 in front and the 255/50 tires in the rear is also 1 inch. The total reduction in the front height is 2 inch, combined with the fiberglass monospring in the back which raises the height of the rear by about 0.5 - 1 inch, for a total reduction in the front to 2.5-3.0 inches. See picture below! Hope that helps.
http://s894.photobucket.com/albums/a...3.jpg&newest=1
Adam
Rears are 18x9.5 with 4.875" backspacing on stock trailing arms. There is plenty of clearance and if I had it to do again, I would go with 5-3/8" backspacing to tuck them under a little more.
Thanks I may go a with 7 wide up front. I am working on painting my car now so wheels are next. Thanks for your help.
Adam
Adam
Also, if you have the steeroids steering kit you have to keep that in mind too. I tried 5 different wheels until I settled on a particular setup. Remember, most places say once you mount a tire... you own that wheel lol. Think I might turn that 225 dollar wheel into a clock for shop wall....
Best of luck!
