How do I get rid of the ecm
Two things really....distributor for a 75-80 model year chevy/pontiac/buick....and a non computer carbuerator. That should be it for a 4spd car. An auto may require something else for proper tranny operation. I'm just not sure.
#1. Pull off the distributor, the carburetor, the ECM, the wiring harness (for that control system) and the sensors that you no longer need.
#2. Send them all to me at my shipping expense.
#3. Install another carb and distributor [either points-type or HEI].
#4. Accept my humble thanks for the nice 'gift'.
Just to clarify this a little, it must be from a small block (or big block) Chevy, which could be had in some other Buick, Olds, Pontiac-but so could Buick, Olds, or Pontiac engines be found in Chevys (not Corvettes). You need an HEI distributor from a 262, 305, 350, or 454 (pickup) Chevy engine of this time period. The 366, 427, and 454 tall deck truck/bus distributors won't work either.
Just for the record... I understand your desire to go with a standard HEI distributor and basic Q-Jet (or Holley...or whatever); lots of folks do the same thing. But I was NOT being flippant with my previous post. I really would like to refurbish your ECM system/dist/carb and stick it on my '71 coupe. But, no one wants those parts so they throw them away and I can't find a complete set.
I have a "basic" Q-Jet carb [1201 Edelbrock] which has been rebuilt by Lars Grimsrud and works great. If it will sweeten the pot any, I'll send you my carb as a good, working replacement for yours. You should just be able to bolt it on and go. As for the dizzy, mine is a points unit and I'm sure you wouldn't want it. But GM HEI units are easy to find. Then,put a toggle switch on your converter lockup feed wire and you should be "good to go".
I'm still willing for the trade...and shipping is my responsibility. You'll get [most of] what you want and I'll get what I want. Interested?
Will
