KoraSar C3 Exhaust
Cruising
KoraSar C3 Exhaust
Hi, Can anyone tell me where I can get a "true dual exhaust system" installed, in Mechanicsburg, PA? I have antique plates and no need for inspections anymore... Thank you'all.
Buy the exhaust from Mid America and have it installed at the shop of your choosing or have a local shop custom bend one for you. The Mid America option will be easier and cheaper!!
I bought the hooker headers dual exhaust from jegs and I installed it myself with no problem, just make sure you get the hooker headers, dont try to save money and get the cheaper headers cause it wont work without some modification, the dual exhaust kit is PN16521-$170 and the headers are PN2456 -$190, then what ever mufflers you decide on.
Cruising
What about this, from Mid America Motor wWorks?
1968-1982 Corvette Aluminized Steel Chambered Undercar Dual Exhaust Turn The Key And It's The Sounds of 1965 Again!
*Side Exhaust Sound And Performance With Undercar Exhaust Looks
Our technicians have designed 1968-1982 Corvette Aluminized Steel Chambered Undercar Dual Exhaust Systems utilizing chambered sections similar to the ones used on 1965-67 factory side exhaust. These 2.5" systems fits in the stock location with no modifications. 1968-73 utilizes your stock extensions, exiting through the rear valance panel. The 1974-up systems are supplied with turn-downs similar to the stock muffler tips. Exhaust extensions sold separately. The chambered sections give a deep, powerful side exhaust burble at idle and cruise speeds, easily allowing conversation or stereo listening. But when you "stand on it", your Corvette will have that great side exhaust growl! Make your selection by year, and type of transmission. Fits 327 & 350 "small block" engines or 427/454 "big blocks" engines. Comes with clamps and manifold gaskets. Manufactured from 14-16 gauge aluminized steel tubing.
I would just spend a little extra and get the headers now cause your probably gonna want them later on anyways, if you want that chambered sound just go with strait pipes no mufflers. I went with hooker max flows and it sounds ok, not exactly the sound I was lookin for, they have a nice deep tone, I wanted something louder but deep. I should have went with strait pipes. Like I said though if you choose the hooker set up get the hooker headers jegs told me there headers would also work and they didnt. The only thing I had to do was remove the starter to get the passenger side header on and i removed the dipstick tube and alternator on the driver side, you have to remove these parts even with the hooker headers, make sure you put the intermediate pipes throught the crossmember before you put the headers on. it was very easy. Also the hooker set up flows better,
