Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-27-2010, 02:27 PM   #1
Ray Y
CF Senior Member
Ray Y's Avatar
Default Wiper Door-- electric conversion questions
I've searched the old threads on this topic and have found where some of you guys have converted the wiper door operation from vacuum to electric operation, but I can't find any posts that actually have photos of what you used. I'd love to see some photos of what you have done.
If you have done it, which way did you go: linear actuator rod or rotary actuator and why?
If you went with the linear set up, what stroke length?
I look forward to seeing some examples of your mods.
Ray Y is offline   Reply With Quote
Old 04-27-2010, 02:43 PM   #2
ZBRA
CF Senior Member
Support Corvetteforum!
ZBRA's Avatar
ZBRA is offline   Reply With Quote
Old 04-27-2010, 08:43 PM   #3
KSM
CF Member
As large as the vac actuator is and the long rubber boot that covers the rod..........I would fit a screw jack actuator inside the vac valve and boot and no one would know it was their.
I just fixed my wipers and door but next time I will go the electric route for sure.
KSM is offline   Reply With Quote
Old 04-27-2010, 09:29 PM   #4
Garys 68
CF Senior Member
linear actuator. Used 2 relays to change polarity. The actuators internal limit switch stops at closed. I use a dpdt microswitch instead of the spst wiper door switch to limit the door open, and energize the wiper motor. Works like a charm.
Click the image to open in full size.
Garys 68 is offline   Reply With Quote
Old 04-27-2010, 10:52 PM   #5
Ray Y
CF Senior Member
Ray Y's Avatar
Gary,
That is exactly what I'm talking about! Thanks for posting the pic.
What stroke length actuator did you use?
Do you remember the manufacturer?
Old 04-28-2010, 01:18 AM   #6
Garys 68
CF Senior Member
I eliminated all but the main arm of the mechanism and used a 2" acuator.
http://www.firgelliauto.com/product_...roducts_id=136
Old 04-28-2010, 06:44 AM   #7
mrvette
CF Senior Member
mrvette's Avatar
I used a ~6" actuator, Chris, 69myway, got it for me, I used Radio shack burglar alarm contacts with magnets on the door itself, the reason is they are waterproof, microswitches are not waterproof, and in the wet may well fail....the contacts are readily available and cheep too....
the relays are basically easy...I used 3 of them, could go Solid state if I wanted to, but why bother?? the red WSW wiper motor wire is not needed, I put in a more 'normal' GM wiper motor setup, sans the pump action, used a 15 buck aftermarket pump and a button for that action...
I glued one contact to the windshield, and the other to the grill in front, two magnets on the door....4 wires through to inside behind the map pocket area where the 3 relays are glued/wired together with the main power relay support bolted to the cowling...ground to another bolt, one of the relays is a reversing relay, sole purpose is to reverse the polarity of the motor +- wires, the others are to turn on/off, and interact with the switches to limit the travel....
been there about 4 years now...
__________________
GENE
"Liberalism is a disease of the terminally stupid."
All products should say "Do not use if your stupid"
http://s1005.photobucket.com/albums/af176/mrvette72/
http://mrvette.shutterfly.com/vette2011
mrvette is offline   Reply With Quote
Old 04-28-2010, 08:07 AM   #8
...Roger...
CF Senior Member
...Roger...'s Avatar
Pics man we need pics
...Roger... is offline   Reply With Quote
Old 04-28-2010, 08:11 AM   #9
...Roger...
CF Senior Member
I guess I'm going to have to look into this but is there any reason you couldn't set this up like power door locks,push the toggle and it opens then push the toggle to close ? (no relays )
Old 04-28-2010, 09:11 AM   #10
Garys 68
CF Senior Member
That's the easiest solution. I just wanted mine to work off the factory switch. Besides, relays are cheap, a couple bucks each, and the dpdt limit switch was under $10 and fit perfectly where the original wiper door switch fit.
Old 04-28-2010, 09:17 AM   #11
noonie
CF Senior Member
noonie's Avatar
The Firgelli actuators are pretty decent. We use them all time for linear motion.
noonie is offline   Reply With Quote
Old 04-28-2010, 02:31 PM   #12
Ray Y
CF Senior Member
Ray Y's Avatar
Thanks for the added info.
I had found the Fegelli actuators on the internet, and also saw some from AutoLoc, part # 6179E, that were only about 6.25" (158mm) long. I'll have to go back and look at the FA's but I think they were almost 10" long for the 2" stroke.
Keep the info coming!
Old 04-28-2010, 02:35 PM   #13
Ray Y
CF Senior Member
Ray Y's Avatar
Oops....website is www.route66supply.com
Old 04-30-2010, 06:31 AM   #14
AAJC
CF Senior Member
AAJC's Avatar
I did mine over 25 years ago. I didnt know about actuators then, so I used a Mazda RX7 pop up head light motor.
I welded its mounting bracket to the vacum mounting bracket, modified the vacum shaft to fit on the rotary arm of the headlight motor. Then used a DPDT relay to sense power to the wiper motor to lift the wiper door when power goes to the wipers & more importantly not close until the wipers are parked.
I havnt touhed this setup in 25 years & it works every time.
If you want to go down this path, I will try to post some pics.
Otherwise, goodluck with whichever method you decide to use.
Cheers from Aus.
AAJC is offline   Reply With Quote
Old 04-30-2010, 10:42 PM   #15
Ray Y
CF Senior Member
Ray Y's Avatar
Thanks Andrew. I'm guessing the linear actuator is smaller than the Mazda setup, but if you can post a pic I'd love to see how it looks. I have not ordered anything yet, but I need to within the next week.
Old 05-01-2010, 09:41 AM   #16
carriljc
CF Senior Member
carriljc's Avatar
Default Please post the pics AAJC.....
sounds a little different....and interesting
carriljc is offline   Reply With Quote
Old 05-10-2010, 07:38 PM   #17
TOM B1
CF Senior Member
TOM B1's Avatar
Cheers from Aus.
I like this idea and would like to see some pics AAJC
TOM B1 is offline   Reply With Quote
Old 05-10-2010, 08:50 PM   #18
MrForce
CF Senior Member
St. Jude Donor '11, '14
MrForce's Avatar
Send a message via AIM to MrForce
pics please
MrForce is offline   Reply With Quote
Old 05-10-2010, 09:08 PM   #19
Fastguy
CF Senior Member
St. Jude Donor '03-'05
Fastguy's Avatar
I am hoping to do the same thing with mine.
Fastguy is offline   Reply With Quote
Old 05-10-2010, 10:17 PM   #20
Ray Y
CF Senior Member
Ray Y's Avatar
I wound up ordering the linear actuator from Route66Supply.com that is from AutoLoc that I referenced above. Awaiting delivery now. I'll post an update after I get it.
Reload this Page Wiper Door-- electric conversion questions
Tags
1968, actuator, bracket, c3, conversion, corvette, door, electric, electriccial, forum, limit, switch, vette, windshield, windshild, wiper
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
