1980 vacuum hose diagram and kit
Old 04-23-2010, 01:42 AM
glarior
glarior's Avatar
Default 1980 vacuum hose diagram and kit
I need a diagram for the entire vacuum line setup on a 1980 vette. Where can I find one? I can find the headlight but thats not what I need. Its time to replace all the lines. Also who sells a full vacuum line kit?
Also, what are the major components that I need the vacuum lines for? Trans, carb, headlights, brakes, cruise control... what else?
Old 04-23-2010, 11:49 AM
glarior
glarior's Avatar
anyone?
Old 04-23-2010, 01:32 PM
...Roger...
...Roger...'s Avatar
This should help,if not search the Willcox site ,he has most of the vacuum diagrams.
http://willcoxcorvette.com/instructi...82_secured.pdf
Old 04-23-2010, 04:32 PM
Project80
Project80's Avatar
Dr. Rebuild - great emission hose kit!
http://www.docrebuild.com/dr-r-web/EMISS-HOSE.HTML
Old 04-23-2010, 05:40 PM
KENS80V
KENS80V's Avatar
Here you go......
Old 04-23-2010, 11:28 PM
Gale Banks 80'
Gale Banks 80''s Avatar
If you are doing a restoration You will want a correct kit and not just any kit. Dr Rebuild if I remember corectly in NY makes as good of Kit as anyone. The diffrence is how the Hoses are Striped. If its not a restoration any Kit will do. Most of the major Vendors sell the above kit if you tell them what your doing. Some of the more detailed diagrams have the Hoses wrong for the 80-82 at the headlights. The 80-82's have the Vacume cans opposite. The left can is on the right and the right is on the left.
Old 04-24-2010, 01:15 AM
glarior
glarior's Avatar
Originally Posted by KENS80V
Here you go......
Think that will work... thanks
Not a restoration... my daily driver :-) However, I can hear the leak and now my trans is shifting at 3.5k...The modulator valve is new....but the high pitch sound is louder... hehe. I know I have more leaks so may end up replacing everything. I will find out for sure tomorrow... Thanks for the info
Old 03-18-2013, 12:13 PM
twk1946
twk1946's Avatar
I can hear the leak on my 1980 at the vacuum select switch, hoses seem to tbe ok. Should replacing the switch solve the problem
Old 03-18-2013, 12:20 PM
glarior
glarior's Avatar
Could be... Check out this link... http://www.corvette-101.com/vacuum.htm
It is the best link I have found to troubleshoot vacuum on the vette.
To 1980 vacuum hose diagram and kit
Quick Reply: 1980 vacuum hose diagram and kit
