Corvette V12?
Old 04-19-2010, 11:49 AM
Richard454
Richard454's Avatar
Received 3,218 Likes on 1,730 Posts
Default Corvette V12? The BUILD....
If you've been around a while- you've seen this one-
A Pacecar w/ a Jag V12-
Boy-this guy gets flamed....
http://forums.corvetteforum.com/c3-g...h-the-v12.html
And here's my idea/ project a BMW V12- NO frame mods/NO firewall mods/ Stock motor mount bolted to a mount I made that bolts to the stock V12 block mounts- Will even fit under a small block hood....
It fits- w/ no real issues-
What do you think??? Or Flame away......
Richard
The following 2 users liked this post by Richard454:
CV71H (01-05-2020), scotty t (10-20-2017)
Popular Reply
11-07-2019, 12:20 PM
Richard454
Richard454's Avatar
Thanks guys!!! I got all the gas pumped out - the new Holley Hydramat sucked every last drop out- I like it!!!
Gotto go get some fresh stuff- the old stuff goes to the lawnmower!!!
Originally Posted by L-46man
I read this thread from end to end.... While I applaud the poster greatly for putting a QUALITY BMW V-12 in the car and all the fantastic detailed work it took to do it, I took exception to the JAGUAR V12 picture posted....Please do not impugn my ability to read or comprehend....look carefully and you'll see it.
John's Cars in Dallas made and is making a 50 year fortune on removing the British lumps from JAGUARS and putting SBC's in them....hence my horror of the vice-versa.
Unkahal PHD.
Of course Chevy made a show car with a 12 Cyl.
This has been done a number of times.
I used to have a JAG E-type V-12....probably the lousiest car I've ever owned. (The engine that couldn't do ANYTHING right).
I guess the whole point is...what's the point?
My point is - "Because I can!!!"
Its a restomod- that I didn't just click on various Websites and then just bolt the pieces on.
Just about all of the stuff is designed & made by me-
When I open the hood- this is what I see - and proud to say- "I built it..".
BMW V12 M73 ALL aluminum-
Old 04-19-2010, 11:59 AM
jordan89
jordan89's Avatar
It's definitely something I've never seen done. I wouldn't do that to my Vette. He should have just built his original engine.
Old 04-19-2010, 12:22 PM
Hauq`
Hauq`'s Avatar
That is one of the coolest swaps I've seen. I'd do that in a heartbeat if I found that engine before I built mine. Is he able to run a manual transmission behind it?
Old 04-19-2010, 12:36 PM
SteveG75
SteveG75's Avatar
Jag V-12's are nice but down on power compared to a small block Chevy.
GM did try a Falconer V-12 in a C4. 601 cubic inch, 660-horsepower and 782 ft./lb. of torque.
http://www.corvettereport.com/corvet...ette/#more-799
Old 04-19-2010, 01:05 PM
Richard454
Richard454's Avatar
[/IMG]
Jag V12 are nice- but about as heavy as a Cast Iron big block (685lbs)
However- the BMW V12 I'm gonna run with weighs in about 500lbs- fully dressed - A little more than a LS1.
As far as power goes- About 300HP in stock form. I've pulled all the accessories (A/C & P/S) and setting it up w/ a dry sump-a little clean up and I really will only see about 350HP. So- really close to what my original LS-5 made back in the day.
Hauq- Manual transmission is not a problem- The BMW 850's came w/ a 6 speed-and they are not too tough to find.
Richard
Old 04-19-2010, 01:21 PM
Shark Racer
Support Corvetteforum!
Shark Racer's Avatar
Can you get it to 850CSi trim?
Old 04-19-2010, 01:41 PM
TheFinn
TheFinn's Avatar
I like it!
Old 04-19-2010, 01:44 PM
gerry72
gerry72's Avatar
That's pretty cool for sure. I'd like to hear the exhaust note on the thing.
Puniphorous (01-29-2020)
Old 04-19-2010, 01:54 PM
73StreetRace
73StreetRace's Avatar
Me too ! That's an unbelievable engine. Nice pictures !
Old 04-19-2010, 02:10 PM
MN-Brent
MN-Brent's Avatar
You should go for it and set up a thread to show us your progress on the way. Sounds like a lot of fun!!
Old 04-19-2010, 02:35 PM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
It's but the low HP would deter me
Old 04-19-2010, 03:40 PM
larryg3
larryg3's Avatar
go for it and post progress pics.
Old 04-19-2010, 03:55 PM
Snoopysvet
Snoopysvet's Avatar
I bet it will sound awesome
Old 04-19-2010, 04:15 PM
Bowerss2
Bowerss2's Avatar
i like it!
Old 04-19-2010, 04:55 PM
Richard454
Richard454's Avatar
Thanks - I will keep the pics coming
Everywhere I go- Somebody will always say/claim they (or a buddy/cousin/neighbor- etc) has more horsepower....
Very few can say they have a V12!!!!
As far as more HP-or 850 CSI motor- it gets expensive $1300 cams times two...Stroker crank $4000. Chips are $400 but only worth 30HP.
I got the motor out of a 1990 750IL - on the cheap- I bought the complete car for $700 (yes-Running and driving- original paint never wrecked)
Here's one of the swaps that gave me the idea-
Is a Datsun 240/280Z w/ a GTO replica body on it and a BMW V12 powering it-
The following 3 users liked this post by Richard454:
73sbvert (04-29-2020), bowtie racing (02-27-2020), Pegan2261 (08-15-2021)
Old 04-19-2010, 05:00 PM
TheSaint
TheSaint's Avatar
When putting that BMW V12 in, there got to be a lot of electrical work to be done? Much more than putting the engine in?
Should have been a CSI engine but i suppose thats a lot more $
Old 04-19-2010, 05:23 PM
Richard454
Richard454's Avatar
Actually- thanks to reading the Lambo Kit Car building forms- these guys have mapped out all the wires. I'm using the stock computers (1 for each bank of 6cyl and one that syncs them-3 total).
Before I pulled the motor - I clipped wires and made sure everything worked correctly- I even wired the electronic throttle under the hood and made sure it worked-
Electronic throttle-
In addition to the six wires for the drive by wire throttle- have only 3 check light bulbs to wire- power/switched ignition/ ground and fuel pumps (2). It's really not that tough.
The dry sump has also been done before- BMW uses a two part oil pan and I just have to cut a piece for the lower pan- add some hoses/pump and tank.
To Corvette V12?
Old 04-19-2010, 07:16 PM
Bee Jay
Bee Jay's Avatar
That's a good looking replica. I wonder why they didn't put a Ferrari V12 in it?
Bee Jay
Old 04-19-2010, 07:31 PM
Ganey
Ganey's Avatar
V-12s are cool, but it's power & performance that counts!!!!!!!!!!
Old 04-19-2010, 09:20 PM
72LS1Vette
72LS1Vette's Avatar
That engine scores high on the uniqueness scale but if you want performance equal to that go with a lightly modified LS engine.
Rick B.
Quick Reply: Corvette V12?
