Corvette V12?
#241
another forum I am on does it for free but it is a smaller site.
#242
User CP>Pictures and Albums>double click picture>share>copy
I'm sure there's a pic limit depending on membership level...don't know what limits are.
#244
Received 3,231 Likes
I have been using Photobucket- Flickr - my own website and the Corvette Forum to host pictures the last couple years- when PB keep telling me they wanted money as I was going over their limit...screw them...
I don't get how you can have 100 million users and not be able to make a viable business out of it? But what do I know... Anyway- going through slowly and replacing the pics...
Past few years the V12 has sort of become garage art- just sort of piddling with it...had to drop the trans as the hydraulic line broke...couple steps back- as I re-engineered how it was done- A little notching on the bellhousing and I was able to solve the issue.
I got a wild hair and decided to redo the interior to mimic a Lamborghini Miura-
Lambo-
My mimic... not finished - but you get the idea
Gauges- actually mantle clock glass and trim
Gauge mock up- went w/ oil temp gauge as I'm running a dry sump
Lambo-
#245
The exhaust and oil lines where having a tough time coexisting...
Dropped the pan- and got some 90º fitting-polished up while I was at it....
Put some heat shield on the oil lines- now fit nice and tight against the block-Don't look too closely at the exhaust...that was some steel I had laying around for mock up...
Down pipes- 304 SS polished it up too!
Side pipes- actually two pipes in one- 2½" straight pipes and w/ electric cutout I can run a glasspac
#246
And while I was at it...
I added electric steering- from a Nissan Cube
Since I'm using a pushbutton start- I put the controls for the wiper in the steering column- the wiper motor is off a C4- delay module is off a late 90's Caddy.
#247
I also went with a new set of injectors....trust me- they are NOT cheaper by the dozen!!!
while I was at it- redid the the fuel rails mounting and hid the injector wiring w/ some copper tubing-
Also added screens to the velocity stacks-
#250
Thanks guys!!!
The project I'm messing with right now- is getting nice clean-cool air to the engine-without having a big airbox covering the polished velocity stacks.
I really like the look of this hood vent/scoop
So here's a start on mine-
Here's the airbox mocked up- Idea is to make it part of the hood and have the rubber gaskets seal the stacks- just have two gaskets right now...need about 10 more!!
Looking at having the airbox incorporate into the hood as well...
M Pete (08-22-2017)
#252
Keep in mind that that scoop was designed by the stylists who put it where it looks like it would work the best and not by engineers who would put it where it really would work the best. I would think that drawing air from the cowl would be where the engineers would and did with the L88 design.
Please tell us more about the Electric Power Steering. I think its just a matter of time before the aftermarket points us in the route. Just the same way that Rack and Pinion has been reverse engineered to fit our cars. Why have very little PS with the engine idling when You need it and lots of PS when the engine is up to speed and you don't need PS. That's the way Hydraulic PS works now.
#253
THANKS...I do too- one day I'm going to drive it!!!
Yep the scoop is a compromise...BUT getting cold air to the engine and it looks good...I'm running fuel injection not a carb...so the electronics will compensate..Ram effect? Don't know? New Vettes run a similar scoop...
I'm using one from a 2010-12 Nissan Cube- Including the adapter-I'm in a little over a $100.
Had to mod the steering column-and found a u-joint that would accommodate the Nissan electric assist motor to connect with the stock box- Just have to connect to power/ground /ignition and mount a control box.
Here's a great read on "How to" electric power steering-
https://www.corvetteforum.com/forums...nd-videos.html
Here's what I have run into-
1) If you want to have the collapsible steering shaft- taking the column apart and cutting is required.
1b) If you don't want to retain the collapsible steering column- Taking apart the column and cutting is required!!!
1c) Tilt-Tele- that's going to take even more work...
2) You have just about 9" between the firewall and stock steering box- if you are running a manual trans - you will need to convert to a hydraulic as there is no room for the Z-bar....
3)You will loose the reverse lock-
Here's my cutting-
Stock shaft- blue tape indicates firewall
Stock shaft cut- and inner stack shaft was cut to retain collapsible. Nissan steering wheel adapter
Nissan adapter turned down to fit cut-down OEM shaft
This will get welded
Fits into motor's torque sensor tube
Looking into the column-
Nissan bracket- fits almost perfect in the OEM column. A little more work (probably notch the OEM column) and it will be welded to the firewall bracket.
Here's what it looks like- motor slides into column- just have to design a mount to the frame for the motor.
Control module-
Here's my cutting-
Control module-
#254
Thanx for the update and all the Pics on how You did the EPS. And yes a great blog on all the EPS systems out there some how I had not seen that one. Amazing the knowledge these people have including you. The Late Corvette Rack and Pinion with the EPS Motor in it caught my attention. Since I have all ready done the Steeroids it might not be that hard to do. But it must have a separate controller, and probably not the fail safe that is so popular with the Japanese cars.
#255
Here's my cutting-
Control module-
Here's my cutting-
Control module-
OldCarBum (10-16-2017)
#256
I've been buying a bunch of little bits and pieces...even got a new Dewits Radiator-
Had a Dewiits one for my mock up- got damaged while in storage - and just couldn't stomach buying another one. Put a Champion in that I got for a little more than a C note- fit like crap- just don't like the idea of something as important as a radiator then going cheap...So I am pulling it out and redoing- a couple steps back...but I'll feel better about it!!!
I mean look at these welds!!!!
#257
Richard, the Dewitts radiator is an excellent product. The one they made for me had two modifications included at no extra charge. The temperature sensor bung on the driver side and a -6 AN bung for the big block expansion tank connection on the passenger side (trans cooler was also included for $30).
A 3/8" compression to -6 AN on the expansion tank reduces the chance of that little hose causing a big problem.
#258
AHHH- that's a great idea- already have fittings on the Canton expansion tank- and AN line to the Radiator- but used a faux AN fitting. I did the cardboard cover too.
I have two temp sensors- both in the coolant crossover pipe between the heads- one is a GM sensor which the original dash gauge uses- just added a bung for it. The second is the OEM BMW sensor which feeds the ECU- and I can read it on the I-phone and it is logged.
Also have a oil temp sensor in the bottom of my dry sump tank-using a original gauge from a 80-82 refaced to match.
So I should be good to go as far as reading temps!!!
I've got to get some exhaust pipe welded- Looks like the radiator is going to my buddy's shop too!!!
Old radiator coming out-
GM sensor in the x-overpipe
#259
Time for some updates-
I have a set goal to get this thing on the road- first of June!!!
The Hotrod Power Tour is in my backyard this year- so figure I can either limp home or towing won't be that bad!!!
Here's the stops-
Saturday, June 9 – Bowling Green, KY
Beech Bend Raceway Park
Sunday, June 10 –Chattanooga, TN
Chattanooga State Community College
Monday, June 11 – Hoover, AL
Hoover Metropolitan Stadium
Tuesday, June 12 – Hampton, GA
Atlanta Motor Speedway
Wednesday, June 13 – Darlington, SC
Darlington Raceway
Thursday, June 14 – Raleigh, NC
PNC Arena
Friday, June 15 – Concord, NC
zMAX Dragway
Here's what I have been up to-
The cooling system-
Had a leak behind the waterpump ( used air to check for leaks)- it was a NPT fitting that I had blocked off- impossible to get at...So started taking of the front oil pump drive - serp drive and then decided to go to Harbor Freight and get some sacrificial tools. I grinded a couple sockets and hex key up and was able to get to it.
Leak stopped...however found my bran new radiator cap on my expansion tank was leaking- a spray bottle with soapy water found it.
Got a really nice piece off eBay for under $20-
I got an AN fitting welded to the new radiator-
And while I was at it- I redid the angle of the tensioner on the serp drive- got a new pulley (smaller) and made a new bracket out of aluminum-
Ready to go back together-
The exhaust is pretty much figured out-
Here's the removable piece- so I can take the muffler apart-
Uses factor frame mount-
All put together- O2 sensor bung in
Now to finish up the brakes-
Got a Eastwood double flare tool-
And after doing some research - found out that I needed a 7/8" bore versus the 1" bore already bolted on- haven't put fluid in it yet.
Here's the stops-
Darlington Raceway
PNC Arena
zMAX Dragway
The cooling system-
