I have a 71 vette that was sitting for 2 years. Stock 350 setup.
Has an Edelbrock carb with electric choke. It starts and runs fine and idles nice while the choke is on but once I kick down on the gas to cut off the choke it won't idle anymore, just dies.
So long as the choke plate is closed it idles perfect although a bit fast.
I've tried to adjust the 2 spring loaded screws on the front of the carb but it doesn't change a thing, the engine dies without the choke. I'm think this is carb related.
When I rev over 2500 rpm i'm getting some backfiring as well. I've tried to speed up the idle screw as well but that didn't help either.
Any suggestions as to where I should start, engine sounds healthy with no smoke knocking or any valve noise.
