1/8 mile drag question
hello, can anyone let me know what kind of power i need to make to run high 7s in the 1/8mi. i have an 80 vette that weighs 3100 race weight. it has a 3000 stall, 3.73 rear, 26in MT slicks. im just looking for an approx. number. thanks
I believe that motor showed 340/350 RWHP before it expired @ PINKS last weekend
I think 350 flywheel hp would be enough. Using some hp/weight/speed calculators, I estimate my hp at 350. I'm running 8.0 in the 1/8 th, but with more weight, around 3,400. Same converter and rear as you.
I had a 78 trans am that ran 7.60s@89 with a mild 406" Pontiac. The car weighed 3600lb with me in it. 3.42s and a 10" 3200 stall. Suspension worked well...1.59 60's. Never dynoed it hut our best calculation was 425 crank hp....the converter was not efficient though.
This was just for comparison sake.
A friend of mine who passed away a few years ago had a 67 Camaro we built for him that ran 7.60's in the eighth back in the 80's. The car was a very low buck build. 350 two bolt block .030" over with a cast crank, cast 12 to 1 generic pistons from PAW, an old TRW flat tappit cam with .480 lift and 235 duration @ .050", 461X Fulie cast heads I ported and did valve and seat work on, Z28 springs, stamped steel long slot rockers from PAW, a Holley Z28 intake manifold knock off I think they called the Street Dominator, 650 Holley Double Pumper with 1" open plate, open Hooker Super Comp headers, 350 tranny with a shift kit and a real cheap 3500 stall converter, 4.56 gears and used 28x10x15 slicks off my buddies Top Fuel Harley.
It infuriated a couple guys we knew with high buck cars because my buddy Bill always beat them. Can't tell you what the horsepower was. It never got near a dyno. The motor still runs to this day. His daughter has the car.
