Backfiring. Cold and out of time or something else?
Ok now I am just gunshy and paranoid. I fired the car up today for the first time since no oil pressure. I heard no knocks, grinding , banging or any other bad mechanical noises. What I did get was some back firing out of the right side. I did not have a chance to get the motor warm because the oil filter did not seal (yet another set back). Did the backfiring occur because it had not gotten warm and I was just close enough on the timing after reinstalling the distributor to get it to crank? Something else? I did check the valves and they were all set the same as they had been for about the last year. So this tells me I don't have a valve train problem. Was it just cold and out of time?
On the oil filter issue. For some reason the filter is not sealing to the block with the old stock bypass adapter installed. Is that peice supposed to have a gasket between it and the block? I never had one before. I have tried 2 oil filters and neither has sealed. The leak is in the same location each time so that leads me to beleive that the oil filter adapter is not installed correctly somehow.
Wade
Wade
How much did you crank it before it started. could you have flooded it enough to fowl the plugs. fowled plugs will delay spark therefore causing a back fire. Timing of course can cause a back fire could you have put it back a tooth off or maybe 180 out.
Right now I have a floor full of kitty litter to soak up the 2 qts of oil that got pumped out. Once that is done i am pulling the filter and the stock bypass adapter off and replacing with the O-ring fitted adapter I used before. That part was not the culprit last time. It was the sandwich adapter and my own stupidity that appears to have caused the no oil pressure issue. Hopefully when I do this the oil filter will seal as it is supposed to. If not.....
Thanks I will check for fouled plugs. I would think that that is definately possible as it took a while to get it running. It has always been very cold natured, especially after sitting for a long time.
No such thing as "a tooth off". A drunk monkey could drop the distributor into place and as long as the wires, cap, and rotor are in sync, she'll run fine.
And if the distributor was "180 degrees off", it won't run at all. Instead of pointing at the #1 after the compression stroke the rotor would be pointing at the #6 after the exhaust stroke.
I'm assuming you've double-checked the firing order.
Backfiring is usually caused by a vacuum leak causing some lean-out. Our Vettes have a 100 places vacuum could be leaking so start at the carb and work out.
Another possibility is a broken valve spring(s).
FWIW
FWIW
Wade
The bolts for the stock adapter are a special head to clear the filter. If you used regular bolts the filter will not seat. I had to get the bolts from a local dealer & no I did not use a gasket.
If it ran fine before, the popping is probably a timing issue or a loose wire
Jim
Jim
Engine is running. No leaks, rattles, or internal noises. I am still getting a backfire through the exhaust. I did not have time to get it up to operating temperature before my lunch hour ended. I have back fired through the carb numerous times. Would a blown power valve cause a rough idle and back firing???
Wade
Wade
You seem to be a very busy guy. If i were you I would check anything that you did with the ignition this last time you worked on it. When you pulled the distributer did you pull the wires out of the cap or just pull up the cap with the wire on it. Check to see if the rotor faces the #1 plug wire when the crank is at top dead center. It should point at #1 or be 180 out if it doesn't then that could be the problem
That was it!! Plugs must have been shot. Installed new plugs in it and it fired right up! The throttle had a quick response and no backfiring through the exhaust!!!!! I let it run in the driveway for 15 minutes. No leaks,knocks or back fires. OP stayed around 40 and temps around 185.
