81 Fuel sending unit removal
Old 02-20-2010, 10:23 PM
billlee
billlee's Avatar
Default 81 Fuel sending unit removal
Can the fuel sending unit in an 81 be removed without removing the tank?
Old 02-20-2010, 10:33 PM
67toolfan
67toolfan's Avatar
Nope. just recently pulled tank on a '79--no clearance to pull when installed, that & it takes a bit of twisting & contorting to get out when on the ground--just no room to get it through the factory fuel door opening.
Old 02-20-2010, 11:24 PM
...Roger...
...Roger...'s Avatar
Yes but watch you don't chip or scratch your paint around the opening. If you use tape to protect paint use the type that removes easily.
The following 2 users liked this post by ...Roger...:
corkywillis (11-11-2015), golfradict (11-04-2015)
Old 02-20-2010, 11:57 PM
snoopykissedlucy
snoopykissedlucy's Avatar
Is the old pick-up sock on the end of the unit removable and replaceable?
I figure if I place a good enough filter after the pump- i dont need a pick up sock...what do you guys think?
Old 02-21-2010, 09:07 PM
billlee
billlee's Avatar
ok,, looks like we have a tie so far on opinions...but to answer the filter question no you'll want a sock/filter before the pump unless you like being stuck on road side. The sock/filter protects the pump not the carb or f/i.
Old 02-21-2010, 09:24 PM
Rebelrob
Rebelrob's Avatar
I am able to pull the sending unit out. Its a PIA, It required the correct turns and lifting at the same time. Yes to taping the edges, I chipped paint on mine the first time.
Not sure if 81 is different, probably not. Mine has the fuel pump attached to sending unit.
Old 11-03-2015, 12:46 PM
corkywillis
corkywillis's Avatar
Default 81 Sending Unit
I just did it on my 81. It was a tight squeeze but came out easily after removing hoses and tank screws
Old 11-03-2015, 12:48 PM
corkywillis
Default 81 sending unit
81 has a mechanical fuel pump on the engine not in tank. At least mine does
Old 11-03-2015, 12:51 PM
corkywillis
If you have a mechanical fuel pump on the motor that should work otherwise you could suck trash into the fuel pump before it goes into to your external filter.
Old 11-03-2015, 06:43 PM
EIGHTY
EIGHTY's Avatar
You do not have to drop the tank. I removed the fuel tank sending unit on my 80 with the tank in place. You need to maneuver the sending unit around until it comes out through the hole. Not hard...just takes patience to twist it out the right way.
The fuel sock can be replaced. Right now I'm running without one and haven't had any issues.
Old 11-03-2015, 10:51 PM
Big2Bird
Big2Bird's Avatar
Received 1,014 Likes on 808 Posts
Originally Posted by corkywillis
Dont see how you can fit a 7' disc thru a 6 1/2 " hole but I'll give it a try and report back on my 81. I dont know if there was any difference between 80 and 81 fuel doors.
I just did this 2 weeks ago. Just be patient, and take your time. Changing the fuel lines requires some careful planning.
Old 11-04-2015, 09:45 AM
KENS80V
KENS80V's Avatar
I also have removed it in the past without dropping the tank.
Old 11-04-2015, 09:52 AM
golfradict
golfradict's Avatar
Yes, I have an 81, use "Rogers" advice, he knows these cars.
Old 11-04-2015, 09:57 AM
Street Rat
Support Corvetteforum!
Street Rat's Avatar
Yes. I have done this a number of times on my '81. Twist the sending unit counter clockwise while slightly tilting it. It is almost like unscrewing it from the opening. Of course you need to remove the fuel opening door and gasket surrounding the fill nozzle then the fuel hoses on the sending unit as well.
Old 11-11-2015, 12:36 PM
corkywillis
You are exactly right EIGHTY. Thanks for the encouragement ! I just did it on my 81 and it came out very easy. Very tight squeeze though, it took about 30 seconds to pull out after removing the fuel lines and tank screws. Some WD 40 squirted up between the rubber fuel lines and metal connectors helps a lot to get them off.
Old 11-11-2015, 03:12 PM
EIGHTY
EIGHTY's Avatar
Glad to hear it worked out! Did you replace the rubber hoses to the tank while you were there?
Old 11-11-2015, 10:21 PM
corkywillis
Default 81 sender unit removak
I haven't put it back in yet. Will do it tomorrow. Hoses looked good but I should replace them, its just hard to get to them where they connect back to the metal pipes up under the trunk. Had to take the sender and clean the rust and corrosion off to get it to work. Works great now and had to clean the crud out of the tank and make a new gasket. Thanks again pal !
To 81 Fuel sending unit removal
Old 11-11-2015, 10:55 PM
EIGHTY
EIGHTY's Avatar
Can you tell me how long the rubber hoses are that go to the sending unit? I actually need to replace mine...but my Vette is my daily driver.
Old 11-12-2015, 12:03 AM
corkywillis
I will measure them tomorrow and report back to you. They aren't very long, maybe 6 inches but harder to get to.
Old 11-13-2015, 01:00 PM
corkywillis
Default Fuel lines on gas tank
Looks like the left line is 3 1/4 long and right 2 lines are 2 5/8 long
Quick Reply: 81 Fuel sending unit removal
