COMP CAMS Magnum 270H in a '77 L-48?
#41
It would annoy me to no end to spend money on roller tip rockers and still have them be the stamped steel and ball design . Maybe you could find new valve covers that look similar, but are a little taller. Maybe all you need is a small spacer painted the same color as the heads. Don't give up!
Good luck,
John
Good luck,
John
#42
Good luck,
John
Good luck,
John
