77 vette cluncking and grinding
Old 03-08-2002, 03:30 PM
TAFFYJONES
8th Gear
TAFFYJONES's Avatar
Default 77 vette cluncking and grinding
i `have a horrible noise coming from right rear especially in reverse.Just added GM oil 2 bottles and ADDITIVE 1[drained old oil first!]New UJ's on rear,could it be the wheel bearing?or something worse! :smash:
Old 03-08-2002, 03:36 PM
GTR1999
GTR1999's Avatar
Received 2,613 Likes on 1,336 Posts
Default Re: 77 vette cluncking and grinding (TAFFYJONES)
could be bad bearings or a problem with the new u-joints. I would disconnect the 1/2 shaft and check both by sight and feel.
Gary
Old 03-08-2002, 04:47 PM
2ND77
2ND77's Avatar
Logic says...check what you just did. If you hear noises from the area of a U-joint you just replaced...I would check those first. Maybe on is mis aligned or something like that.
Ron
Old 03-08-2002, 06:27 PM
454Big
454Big's Avatar
Default Re: 77 vette cluncking and grinding (2ND77)
One more possible cause on fresh U-Joints can be that you lost a needle inside the cap during installation.
This will lead to detoriation of all other needles in the Cap and you will have a very bad noise under load changes.
Give this a try, buddy!
Good luck!
Old 03-09-2002, 07:20 AM
One GM A Tech
One GM A Tech's Avatar
Default Re: 77 vette cluncking and grinding (454Big)
:cheers: ditto :smash:
To 77 vette cluncking and grinding
Quick Reply: 77 vette cluncking and grinding
