Gauge lights don't work. Please help.
Old 01-18-2010, 10:21 PM
coll1446
coll1446's Avatar
Default Gauge lights don't work. Please help.
I have a 1970 Corvette and I'm having problems with the interior gauge lights. They don't turn on. I recently replaced the headlight switch and changed all the interior bulbs to leds, but that didn't work.
I was told to put a ground on the switch. Any other ideas? Any help would be greatly appreciated.
Old 01-18-2010, 11:22 PM
wrw2497
wrw2497's Avatar
do the parking/running lights work...they are on the same fuse....is all the wiring stock...anyone tapped into for radio or.....
Old 01-19-2010, 10:43 AM
PhyscoVette
PhyscoVette's Avatar
you need tp pull the assemblies apart and check the circuit bords they are known to have small breaks in them.
Old 01-19-2010, 11:55 AM
Peterbuilt
Peterbuilt's Avatar
Received 1,246 Likes on 966 Posts
Default Ground Wire
Did you check to make sure that the 'Harness Ground' (HARN GD) wire is connected to the drivers side hinge post?
Old 01-19-2010, 08:28 PM
...Roger...
...Roger...'s Avatar
The INST fuse must be hot when the light switch is pulled out and rotated counterclockwise , is it ?
(The headlight switch being grounded is for the interior lights but has nothing to do with the dash lights.)
Old 01-20-2010, 10:34 PM
coll1446
coll1446's Avatar
yes the running lights do work & yea it looks stock... weird huh?
Old 01-20-2010, 11:29 PM
wrw2497
wrw2497's Avatar
Default lights
O k...they worked before the switch and bulb change ???...try one of your old regular bulbs...led's are polarity sensitve,only work one way....(just a test)...add a ground wire to the metal part of the switch....(behind dash) hope your dash is open..then try lights....is the switch a repro from ecklers ??
To Gauge lights don't work. Please help.
Quick Reply: Gauge lights don't work. Please help.
