1980 Fuse Box Question
Does anyone know where I can find a diagram showing the amp ratings of the fuses for my 1980 vette? I did find a link showing the fuse layout but no amp info. I also cannot find the info in my shop or assembly manual.
do you have an owner's manual? if so, section 7-5 in the back has it.
if not, i'd recommend buying a reprint owner's manual - it's explained many things i wouldn't have guessed in my 'Vette.
if you need, I can scan and post the page here for you...
The 1980 Owner's Manual (which came with each car) and the Chevrolet Chassis Service Manual both have that info. Other (non-GM) manuals may also have that information.
not to hijack the conversation, but speaking of fuses: does anyone know what the "Auxiliary Fan" fuse if for? My car is missing the fuse for it and I didn't want to plug one in until I know what it does...
I didn't even think about the owner's manual. Unfortunately, I don't have one. The car didn't even have a glove box when I got it. I will look at ordering one.
Thanks for your help.
Cool, thanks for the fuse box diagram. I must have a different shop manual. I have the 1966-1982 Corvette Shop Manual and if I go to the chapter listed on your figure, my manual is covering transmissions.
Thanks again.
Thanks again.
1 Post
Cruise-In VIII Veteran
The AUX Fan is an assist fan on the radiator, its between the belt driven fan and the radiator and is controlled by a 238* switch in the passenger side head. I don't know for sure about the 80, but could be its on the silk screen for the fuse block but not installed.
