Ordering Wilwood Master Cylinder, keep booster or go manual?
Old 03-05-2013, 01:43 PM
Corey_68
Corey_68's Avatar
Default Ordering Wilwood Master Cylinder, keep booster or go manual?
Finishing up one the LS2 swap and need a new MC. Car is originally power but want to clean up space under the good and thinking about switching to manual. I'm thinking with all the weight savings the front end I don't need a booster.
What do you think?
Old 03-05-2013, 01:55 PM
Shark Racer
Support Corvetteforum!
Shark Racer's Avatar
The effort of pushing the brake pedal has nothing to do with how much weight is on the nose.
If you'd like to save space, go with hydroboost.
Old 03-05-2013, 02:18 PM
Corey_68
Corey_68's Avatar
Don't want hydroboost, I want a clean install thus considering to lose the booster.
Old 03-05-2013, 02:23 PM
69ttop502
69ttop502's Avatar
Cory, I went from power to manual because of a cam change and I would't go back for any reason. Much better feel with the manual. This was with all new components. Just changed to the smaller bore master and the firewall bracket to eliminate the booster.
Bill
Old 03-05-2013, 02:38 PM
Corey_68
Corey_68's Avatar
Bill
Good to hear, thanks Bill!
Old 03-05-2013, 02:43 PM
pauldana
pauldana's Avatar
ease of power brakes and better!!
linear feel and overall feeling of manuel...
best of both worlds,,,'''
and like Shark racer said.... it will take up much less room, and looks clean.
Old 03-05-2013, 02:50 PM
Corey_68
Corey_68's Avatar
Looks are subjective...but hydroboost is not as a clean install as I am wanting.
Old 03-05-2013, 03:38 PM
Kid Vette
Kid Vette's Avatar
I have manual brakes and manual steering. Sometimes I miss power steering but I never miss power brakes.
Old 03-05-2013, 04:12 PM
Shark Racer
I'd highly recommend hunting one down so you can feel it.
If you're intending to run without the booster, you'll have to do some clean up work on the firewall. Manual brakes use a 2 hole setup, power uses 4.
Good luck.
Old 03-06-2013, 06:00 PM
69ttop502
69ttop502's Avatar
I used the Master Power Brakes bracket. Very simple and clean install.
Bill
Old 03-06-2013, 06:34 PM
John 65
John 65's Avatar
What about leaving the power brakes and just going with a smaller booster. Thats what I did in my 77, I like it.
To Ordering Wilwood Master Cylinder, keep booster or go manual?
Quick Reply: Ordering Wilwood Master Cylinder, keep booster or go manual?
