Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-22-2009, 09:04 AM   #1
jim2527
CF Senior Member
jim2527's Avatar
Send a message via MSN to jim2527
Default Power steering hoses stuck :(
Steering cylinder: Brass nuts for both hoses loosen but they dont spin freel around the metal tubing. The rubber tubing twists. It looks like the nuts are sized to the tubing. NOT a big deal as I can slice the hoses in hasf
Steering valve: Rock solid. Using a high quality flare wrench and a torch to heat the valve body I can't get them to budge. They're stuck solid. In fact my flare wrench in beginning to slip on them as it appears the brass is soft.
Whhat are my options?
1. Buy a new valve body and use all new hoses
2. Cut hoses leading to vavle body and work on it on a work bench. Using high heat hopefulyl they'll work out.
What happens if they round off? What are my options. As fas as I can tell these are original 1970 parts so they may be siezed up pretty good.
JIm
jim2527 is offline   Reply With Quote
Old 11-22-2009, 09:25 AM   #2
Gordonm
CF Senior Member
Gordonm's Avatar
I don't know what you are replacing but the hoses if they are original should be replaced anyway. If you heat up the valve hot you have ruined the seals and will have to rebuild/replace the valve anyway. Just take everything off and work on it at the bench. If you are replacing it don't worry about it.
Gordonm is offline   Reply With Quote
Old 11-22-2009, 10:13 AM   #3
...Roger...
CF Senior Member
...Roger...'s Avatar
Wiggle hoses back and forth so the line breaks off at the fittings and use a socket on them. I use a 3/8 impact with the air turned down.
...Roger... is offline   Reply With Quote
Old 11-22-2009, 11:34 AM   #4
jim2527
CF Senior Member
jim2527's Avatar
Quote:
Quote:
Gordon, everythings leaking and one of the hoses has chaffed through. It sounds like I should do it on the wrok bench.
Roger, I'll do that with it on a owrk bench. My only fear is that a socket will shear off the nutted part and leave the threaded part in the valve. In that instance I'd probably be better getting a new valve?
Old 11-22-2009, 11:59 AM   #5
...Roger...
CF Senior Member
Quote:
Yes but as Gordon said heating the valve will probably ruin the seals anyway. Good Luck
Old 11-22-2009, 12:01 PM   #6
...Roger...
CF Senior Member
Also don't forget the trick of putting vise grips on the outside of your flare wrench but it is very tight in there.
Old 11-22-2009, 01:37 PM   #7
jim2527
CF Senior Member
jim2527's Avatar
Great tip!! I'll post back later in the week once I'm finished with it..
Old 11-23-2009, 07:58 AM   #8
muskegonbrake
Supporting Vendor
muskegonbrake's Avatar
muskegonbrake muskegonbrake
Send a message via Yahoo to muskegonbrake
If you did heat the valve enough to ruin the seals, you would have to rebuild or replace. I don't usually recommend rebuilding unless you've done it before.
Let me know if you need to replace it. Check out our PS kits if you're interested
muskegonbrake is offline   Reply With Quote
Reload this Page Power steering hoses stuck :(
Tags
hose, line, nut, power, remove, removing, steering, stuck
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
