Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-15-2009, 03:09 PM   #1
nightprowler
Junior Member
nightprowler's Avatar
Default Engine break-in w/ceramic-coat headers??'s
I found this PDF off a Hooker website.
"WARNING! Breaking in an engine with ceramic coat headers WILL result in damage to the coating and will VOID the warranties. Ceramic-coat headers require several heat cycles to fully cure before they will withstand extreme heat. Hooker recommends using a cast-iron exhaust manifold or an old header to break in new engines to avoid coating damage."
I have a new engine going in my car. According to Hooker I would need to run my old exhaust until my new engine is broke in.
Will someone please explain the above paragraph.
How many miles does it generally take for the engine to properly break-in before the ceramic headers can be installed?
nightprowler is offline   Reply With Quote
Old 11-15-2009, 03:23 PM   #2
midyearvette
CF Senior Member
Support Corvetteforum!
midyearvette's Avatar
extreme header heat is usually encountered when a new mill is broken in at medium rpms and run for several minutes and the timing is off(retarded) if they say it will void your warranty i would heed their advice to cya.....jmo
midyearvette is offline   Reply With Quote
Old 11-15-2009, 03:25 PM   #3
marz
CF Senior Member
marz's Avatar
I installed my crate motor, Ceramic Hookers, tires, wheels and fueled her up. I haven't stopped since. I don't know what they mean, but mine didn't become blemished and I broke the motor in with the Hookers. As far as the break in period. Everyone has their opinion. I run mine 500 miles and then change the oil and filter. But, others may run different break in mileage period.
marz is offline   Reply With Quote
Old 11-15-2009, 03:57 PM   #4
Gordonm
CF Senior Member
Gordonm's Avatar
I just broke in a motor with Hookers and it is no problem as long as you are running the carb rich enough and the timing is set correctly. I immediatly set the timing as soon as it fired and purposly ran the carb a little rich on the idle circuits.
As far as break in run it for 30 minutes to break in the cam then have at it. If the motor was put together right no harm will be done. I have done this on countless motors with no problem. Change the oil after the first 30 minute cam break in then again at 200 to 500 miles then normal there after.
Gordonm is offline   Reply With Quote
Old 11-15-2009, 04:12 PM   #5
Jeff_Keryk
CF Senior Member
Jeff_Keryk's Avatar
The break-in procedure generates a ton of heat. I put a window fan (or 2) in front of the radiator. You can also run the heater. Basically, anything that can help cooling is helpful. I agree that you don't wanna hurt those expensive headers...
Jeff_Keryk is online now   Reply With Quote
Old 11-15-2009, 10:10 PM   #6
tnovot
CF Senior Member
tnovot's Avatar
I think the warning is a CYOA thing in case the timing is not set properly. And yes as midyear and Jeff have already said, initial break in does generate more heat than normal use anyway so I can understand how the 2 conditions combined could expose the headers to excessive heat and cause discoloration or coating damage. Better to take precaution than to be sorry later.
Terry
tnovot is offline   Reply With Quote
Old 11-16-2009, 11:11 AM   #7
fauxrs
CF Senior Member
fauxrs's Avatar
A friend of mine's hookers discolored during breakin - odd thing was the timing was right on the money. Cant explain it but I was over there this weekend helping him with brakes and commented, "dude you should got coated headers" he said, "Dude those ARE coated headers dont you remember?" then he showed me a picture of the motor just after install and before break in.
I agree its likely just CYA verbiage that in the case of my friends big block worked in their favor
__________________
1978 L-82, Tremec TKO 5 speed, Sunset Red mettalic, offset trailing arms,
New engine by me
tuned by Lars
My Corvette Web Site
'Idiocracy' was a warning, not a comedy.
fauxrs is offline   Reply With Quote
Old 11-16-2009, 06:53 PM   #8
nightprowler
Junior Member
Thanks for the reply's!!!
I think I will take their warning seriously and install my old exhaust until the motor is properly broken in. No sense in ruining the coating.
Reload this Page Engine break-in w/ceramic-coat headers??'s
Tags
brake, break, breakin, breaking, ceramic, coated, cycles, engine, exhaust, header, headers, heat, hedders
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
