Delay in Headlights Opening - replaced lot of parts already...
Ok, I have searched through the forum, but nothing I have read seems to apply to what I have going on. My Vette is a 1975 .
First my headlights wouldn't do anything, go up or down.... so I started going through the whole system (engine side of car) with a hand held vacuum pump.
First, I went ahead and replaced the vacuum hose filter and vaccum hose check valve.
Next when testing the vacuum on the actuators I found one was not holding vac on rod seal side (drivers side), so took it out and replaced rod seal (witches hat).
Next I found that neither of the relays would hold vacuum, replaced both with new ones.
Now the headlights open and close, but when I turn them on there is like an 18 second delay before anything happens (seems much much longer, but I timed it) and then the passender light comes open first and then about 3 to 5 seconds later the drivers side comes up.
Also, they both open pretty slowly.
They close perfect, nice and fast. Boom.
Also, when I turn the car off and then try to close headlights, nothing happens. I tested the vacuum on tank and it seemed to hold fine.
Any help would be appreciated!!
cc
You most likley need to replace your actuators. Before replacing you can spray some wd40 into the lines (extend/retract) and operate them. This some times is the fix if they are not too far gone. You should do well with the wd40 are they are opening and closeing slowly.
Yes I tested both sides of the actuator. The back sides on both held vacuum.
Interesting - I just noticed that if you pull the bypass the delay is about half as long.... still a noticeable delay, but about half as much. Also, they opened in the opposite order as when I pull the light switch. This time the drivers side comes up, then the passenger.
Spray WD40 directly in the back side input of the actuator?
1 Post
classic 75, I had the same problem with my 79. I replaced the seal that is under the rubber boot on the acutator. it is part number A8263 in the ecklers corvette book. it is called the actuator seal. Real easy to replace, pull the actuator out, remove the rubber boot, remove the seal retaining ring and slide the seal on. I am assuming your headlights are made like the 79s. alot cheaper that $90 per actuator.
That's what I was thinking... I did replace the seal on one already.... but I am willing to try anything at this point. I am going to replace the seal on the other one for the heck of it. Especially as I see now how I can do it in place instead of taking the actuator out... any other thoughts on what else this could be would be appreciated.
One tip for anyone who wants to take the actuator out. After spending at least a half an hour turning it in a million directions trying to get it out throught the front grill opening as is directed in the corvette magazine article I found on-line (and removing the horn to make room etc...)... I found it MUCH easier to pull the hood forward with one hand (it moves another 1/2 inch or so towards front of car when open) and then I slipped it back in the gap from behind the mounting bracket. Took like two seconds. Of course you have to be very careful not to scratch the hood of your car.
actuator
The first time I read this I too thought what the ?? and on my last car when I thought for sure I needed new actuators I sprayed the WD40 and they worked. On my 78 now my lights were a little slow and I sprayed the WD40 and again they work perfect.
In worst case the OP may have to replace the actuators.
