'71 350: How to Get More HP, But Keeping Stock Appearance?
I have a '71 350 convert that will need a rebuild or crate sometime in the future. I'd like to get some more HP, but want to keep it stock looking under the hood.
I don't race, I use pump gas, and I don't care for the loppy idle that a radical cam gives. Having said all that, how would you build this motor?
Received 1,246 Likes
Cheep HP!
For starters check out the 'Sticky' by Barry K (at the top) and re-curve the distributor so that your timing is all in at 2,800 to 3,000 RPM. A $10.00 ACCEL kit will give you a lot more get up and go and your distributor will be all set for the next motor. PG.
I dropped in a zz4 crate engine in my 71 and never looked back. Painted it chevy orange and all the bolt on's from the orig engine fit right up no problem. With the exception of alum heads it looks like it belongs there.
The orig #'s matching engine is in the garage and will go with the car if I ever sell.
Put a 3.75 in. stroke crank in there. Makes it a 383 and no one can tell from the outside. Get a pair of iron double hump heads with 2.02 valves, a bigger cam, up the compression to 10:1 and you will have a 400HP / 450 TQ motor that no one will know it's not the original 350ci.
Then tell them you've never been to the drag strip and you will only bet 100 bucks that's how it started for me
This is a good approach if you want significantly more HP with stock appearance. You also need to bore the cylinders .030 for 383 cu inches. Motorhead is optimistic with 400HP using double hump heads and stock exh. manifolds. I would guess you could add 100HP going this route - that is with a fairly mild cam. I assume you're starting with 200HP.
I'm starting with a stock 350/270HP. I don't want it to idle any rougher than it does now, so I imagine that limits my choice of cams.
Would I be better off storing thr original motor and tinkering with a crate motor?
If you simply rebuild stock 71 350/270 aka L48 ... and replace THREE key things that no one can see ... it'll make noticably more power.
(1) First rebuild replacing L48 dish pistons with small dome Sealed Power p/n H618CP pistons ... and
(2) use thin Felpro p/n 1094 head gaskets ... pistons & gaskets will raise compression about 1-1/4 whole numbers greater than OE rating ... then
(3) Also, replace L48 cam with a slightly larger one such as Summit p/n K1102.
Other than specific pistons, gaskets & cam ... proceed as typical overhaul. It'll still run easy on pump gas but'll make about 40-45 more horsepower than stock L48. And it'll idle almost like stock ... Almost. The H618CP pistons & 1094 gaskets (more compression) ALONE are probably worth 25-30 hp. No one can see those pistons or gaskets or cam.
FYI, if for some reason your L48 idles rough now but you suspect it's entirely stock L48 ... then something's amiss ... because properly tuned & running stock L48 w/ L48 cam is rather smooooth.
-edit- first thing, definately tweek the distributor/ BarryK per Pete's suggestion.
Re the crate motors - they will all look different than your original. If you were to convert yours to a 383 and put a Comp XE262 cam in it, it would idle like a stocker. I know because that's the combination in my car.
You might find some ideas at Brzezinski Racing Products. They do a lot of go fast work on stock intake manifolds, exhaust manifolds and heads. The owner (I believe his name is Randy) is very knowledgable and may have some ideas for you.
I bought some 2.5 inch Ram Horn exhaust manifolds that had CNC work done from them. Parts can be pricey, but they have always been honest and do American quality work which they stand behind. I will buy from them again in the future.
Here is a link:
http://www.castheads.com/
Here is a link:
Overall, a crate motor is your quickest and easiest solution even if you sacrifice some of the original look, in my opinion.
Received 1,877 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Go straight for a 406" motor. Port some 2.5" exhaust manifolds, same with the intake (or grind all the names off a Performer intake and paint it orange). The added cubes will allow for more cam to be smooth. Spread LSA on cam out to smooth it and have LOTS of fun while looking stock!
JIM
JIM
ive asked the same question about stock look more power
ive asked about useing the double hump heads and was told that the acessorys are different and you cant bolt up the a/c ?
You need 1969 or 1970 heads. Casting number ending with 186, 187, 041, 414. These flow decent in stock form but you can port them big time. These can be hogged out to flow big numbers. Combine this with a healthy hydraulic retro roller, Flat top or small dome pistons, 2 1/2 " ramhorns with 2 1/2" pipes into free flowing mufflers and a decent intake painted orange. Easy 400 HP. Looks bone stock. Add a 3.75 stroke crank and bump the torque up a lot.
JIM
JIM
Thats exactly what I did
