My new project 1972 LS1
I scored a pretty good deal on a '72 rolling chassis w/ '99 LS1 that has an Incon twin turbo kit attached. I hope to make this a build thread although I won't be starting any real work on it for quite a while (too many other projects!)
Anyway I've been itching to post up the initial pics and see what you guys think. I'm hoping the Incon TT kit will fit in the C3 engine bay and clear the firewall etc. If not I'll do a mild N/A setup.
Here is the motor up on the stand and the 72 in the background, yellow. That's a 71 LS5 in the background getting a complete suspension/brake overhaul. I'll post more detailed pics of the car/motor later. The overall condition of the car is pretty poor. It was hit in the front pass. side and the entire front clip is damaged. Initial inspection looks like the firewall is still intact. The fenders are already peepling up around the bonding points. I'm surprised the clip stayed attached on the long ride home!
Very nice... Enjoy! We'll have our '72 LS1 driving under its own power in a matter of weeks it looks like.
That Incon kit is junk, you might as well ship it to me and I'll get rid of it for you
Yeah I was pretty surprised it had a complete incon kit on it. The silicone hoses and intercoolers were damaged beyond repair but the remainder of the kit looks to be in pretty good shape. Those cold side pipes would have to be custom made for the swap anyway.
Forgot to mention, I also got a T56 trans with it, which I plan on swapping in as well. I can't wait to dig in
I'm hoping the birdcage/windshield frame aren't rusted as bad as the inner door in the last pic.
How much was the roller if you don't mind me asking? That's exactly what I'm looking for in a project. I'm looking to buy when I get back stateside in a few years.
I imagine that turbo kit will be a very tight fit in there. It's tight enough as it is without one. One thing I can see getting in the way on the drivers side is the steering box... judging from the manifold/turbo pic I see there I think it would run right into it. Maybe custom route them down underneath by the front crossmember or go through the radiator support and use the ducts underneath the headlights for fresh air
NAVY08: Your PM box is full
-Adam
Update
I had a chance Friday to pop open the stuck drivers door and start peeling off what was left of the front end. The original color was Steel Cities Gray, not red which is what I saw under the yellow. I really like steel cities gray so I'll probably restore the exterior just as it was from the factory.
The bad news is the entire front end is damaged beyond repair. Inner fenders on both sides were strung together with fiberglass weave and bondo, as well as most of the surround and both firewall bonding points. In addition there were tons of drywall screws hidden under the gallon of bondo. The a-arms look questionable as well as the frame. I've started calling local frame shops to get an idea of what it will cost to have it straightened and if they prefer to do it with the body off or on? I've heard conflicting stories on this. Anyone have experience with straightening a C3 frame?
Also, the firewall is cracked in several spots.
Good news is the lower windshield/birdcage look promising. There really wasn't any major rust present. The rest of the frame looks very solid as well. I'll get pictures of the underside after I get it up on the lift. For the most part the car is very complete in regards to trim etc so that's good. I also spotted MUSKEGON BRAKE stamped on the diff and the calipers appear to be fairly new.
All in all I'm pretty relieved about the birdcage condition but I'm starting to question my sanity starting this project
I also ran the vin and as expected it was originally a base 350 coupe with auto trans.
I wager everyone here has questioned their sanity at one time or another.
IIRC, BVECTRA has (or had) a front clip for sale. Shoot him a PM. I'm not sure what year it is.
I spoke with the frame shop yesterday. I plan on getting the rest of the front stipped down then taking it in to be checked/straightened. After that I'll start stripping to firewall to get a better idea of just how bad it has been cracked.
The bubba bondo/glass work that was done after the crash is just making things more difficult for me. I wish the last guy would have just left it alone
I have a bunch of 72 front clip parts. I also have a near complete rear 69 clip. I just threw a 69 firewall away! bummer. You are not far from me. Come and get these parts out of my back yard!
Thanks The drivers door was stuck upon purchase and the seller had no idea what the paint code was. I saw a ton of red under the yellow so the 988 tag was a real nice surprise when I finally got the door popped open. I hope the car looks as good as hammadown's when it's finally done;
