The great RAT transformation begins.....
Day 1
Before I started:
The the top end tear down begins:
Running out of room fast....
Tomorrow, I will start disconnecting everything on the bottom side and start getting ready to pull it.....Then I will have TONS of cleaning and detail work to do before the new motor gets here....
Before I started:
Received 1,894 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Have you got headers yet? I've got a set of jet hot coated Hooker 1-7/8" (undercar) if you need some.
JIM
JIM
I gotta get to work on this thing...I want the car ready by the time the motor gets here...
Just a FYI, but if you ordered the 2 1/8 undercar supercompetition headers, be careful. I found them to be unusable on my 69 as they sit so low. The collectors only had about 1/2 inch clearance from the road. Hopefully these aren't what you ordered. Good luck with the project.
Bill
Bill
Bill
Bill
Actually, those ARE the ones I ordered..... only 1/2" clearance from the road? How the hell can they actually sell them if they are not safe for street use?
Seems like quite a few members here have these same headers but...I never checked about the ground clearance...I know they are really close to the idler arm and will likely have to be "clearanced"......Sux if they do hang that low....especially since they are special order and likely can not be returned.
I guess we'll see....
If they don't provide the legal amount of ground clearance for the car, they can't legally sell it in that state. Take 'em to court!
Terrorizing Orange Cones
This looks like a fun project.
Hope you keep better weather down south than up here in the Rockies: crap, it was c-c-cold this past weekend. Best wishes moving forward.
Besides the motor, other "planned" changes?
Next year I will do the rear end/rear suspension with the 12 bolt conversion and drag vette 6 link. Shooting for 10s on pump gas, drive to the track and back with the AC blasting....
I ended up selling those headers and was the main reason I went to sidepipes. I thought about cutting off the flanges and welding the collector to the pipes which would have gotten me a little more clearance but still not enough. They also are very close to the floors as well. I think most guys run the header Jim is selling. The smaller primaries make the clearance better. Now, in my case I am driving on these awful NY roads but those things simply weren't going to work. Just make sure you check them before you dimple them. I had my car on jackstands and put them on, dimpled them to fit at various places, got them perfect. Then I took the car off the stands and as you can imagine, did not like what I saw. I hope they work for you.
Bill
Bill
Longer length on primary tubes, longer length on the collector, wider spread, 1/2 bigger dia. on the collector makes rat headers a pain for exhaust systems.
Oh ya more good news just remembered, because of the collector further back and the 1/2 bigger dia collector I had problems with the collector tube flange burning the fiberglass floor, this is before anybody knew about the danger of asbestos I cut a square patch of asbestos put it on the bottom of the floor board where the flange was very close to the floorboard, this was back in the olden days lol, clutch discs still had asbestos in them, when the clutch companies had to take asbestos out of dics for a long time discs you bought were not worth a flip, took awhile for the companies to come up with a good replacement for asbestos.
I had problems with the lower flange bolt hole this was the lowest point on the header, creep and crawl over the speed bump still it hits grindiing on the flange bolt hole. I was going to cut the triangle shape
three bolt hole flange off, buy a set of the round four hole flanges and cones that would give me some more clearance, but I never did get around to doing it. ALL this is mostly caused by the larger 3 1/2
dia. collector causing headaches.
I sent you a note....but if the engine is still in the car you can do some measuring. The left one ends up about 10-11" in front of the trans crossmember. Measure how moch clearance you have from floor to the ground and subtract 4-4-1/4" or so. That will allow for flanges IF you get them up against floor. Stock heads with stock ex ports put them lower. My Brodix heads have .600" raised ports so that pulls them up tighter to the floor. Also helps around steering box too. They clear the idler arm much better than most...not even close.
Need to think about the crossmember......you will end up with some pretty sharp bends from the headers to make the holes in the crossmember.
I have another set of nice uncoated 2" headers (unknown brand- but I've stumbled into several sets of them)that use 3" collectors I think and are a lot shorter. They don't fit as well by crosshaft on a stick car, but would be great on an auto car. TShort has a set of these I modified (cheap and dirty) on his 427" car and they do well. I ran them on my 540 and my 427 for years. You're welcome to try them too if they might work. They are old...but good!
JIM
JIM
JIM
JIM
If it were me had a nice removeable automatic car trans croosmember.
( my car was a stick shifter ) I would just make another crossmember.
LOL, I just read my first post and I meant to say I had 1-2 inches of clearance not 1/2. But still, I had all the issues that Little Mouse talked about as well, between lack of road clearance and floorboard clearance. I never even got to the point with them where I was going to build the rest of the system.
Bill
Bill
I am going to be in the market for some headers soon. I read about all of the clearance issues and i'm torn as to go with stock manifolds or headers. Has anyone tried the short headers from Mcjacks their number BBCC2X25. They say it's a direct fit for Big Block C3's. They are 2 inch primaries with 2.5 inch collectors.
