GM truck serpentine belt system
Hey, all,
I read about retro fitting the serpentine belt system from late '80s and early '90s GM trucks to earlier gen 1 engines in Car Craft last month. It seems like something I would be interested in doing on my 1980 Corvette, but from some of the pictures, it looks like the alternator and air conditioning compressor will be a little to high for hood clearance. Has anybody else out there tried this with any success?
Scott
Scott
I just put this up for sale
http://sfbay.craigslist.org/nby/pts/1415416772.html
round part next to ac hit throttle body ( of tpi )
was told it was 80s camaro .
Here is a PM I got from a member in the past on this subject.
Dean
Durango_Boy
CF Senior Member
My Corvette Photos
Re: Serpentine set up and hydroboost
Quote:
Originally Posted by Aktbird
Matt, today a guy gave me some parts off a 92 3500 Chev truck with 350. I got all the serpentine system, alternator, ps pump, water pump and all the pulleys. Question is, Will this system mount the alternator too high for hood clearance. I also got the hydra-boost unit from the same truck, is it the right one to use on the vette?
The serpentine system will fit under most stock hoods just fine. I used an F-body setup and have helped a lot of other guys with even the truck brackets. I think the worst fit is under early small block hoods...but you should be okay.
Matt
Dean
Durango_Boy
CF Senior Member
My Corvette Photos
Matt
Hey, all,
Scott
Scott
Here's a pic with half of it bolted up. I was fooling around with the fuel pump (something to consider, stock line to the carb will not work, I'm going with braided steel covered hose) I'll get more pics up as soon as I get the fitting that I need.
I did use the F body power steering pump. I had to modify the pressure line to work but the return line is no problem. You cant se the lines very well but here is anold pic of my pump.
So on the same subject....will a 91 GTA setup fit on a 72 motor? I like the idea of a serpentine setup, and buying a used setup with EVERYTHING included seems like a better way to go than something from Jegs or Summit.
Say a little setup like THIS...!!
http://www.youtube.com/watch?v=fL1JIM5APBk
But I guess that doesn't really qualify as a serpentine setup.
And are there "year" limitations on the blocks that these newer setups can be used on? What I mean by that, is, is there are cutoff on the blocks that would make them not work...ie...too old to mount up??
Jordan
I used the water pump style from the Camaro. It is called a reverse flow pump because the serpentine belt turns the pump in the opposite direction from the standard pump.
mydejavoo
I dont know if there are any limitations on the blocks. I do know that on the passengers side head there should be 3 holes for the bracket to bolt to. When I purchased my set up I did have my heads off and I had the head tapped for just pocket change. When I done my modification I has posted on it and I was told that the third bolt [actually a stud] was not needed but since my engine was apart I had it tapped anyway.
mydejavoo
Honestly, I did not try to hook them up yet as I was planning to replace them and I haven't bought the parts yet. I'm not sure what the pressure hose from a later model vehicle would look like on the end going in to the control valve.
By eyeballing it, it looked like there wouldn't be an issue, but after wnmech's post, I'm wondering why the modification was necessary.
Hopefully he'll post again and let us know what he did to modify it and why he had to.
When I bought my 77 it had no engine or attaching hardware that is why I went with the ease of the serpentine system. I found that the pressure line that came from the pump was a different thread and angle from my hoses. The most I can tell you is if your existing hoses will attach to the pump you should be fine. I was able to get the proper adapting fittings and carried everything to a place that manufacturers hoses and they swedged everyting together and all is good
Just in case I need it, do you remember where you got the adapter fitting?
