DeWitts CF group purchase
Sale ends October30th only! No exceptions
15% off any Direct Fit Radiator, Combination package or Spal fan.
Sale does NOT apply to Restoration Radiators
FREE SHIPPING! ($40-50 savings)
To qualify for the discount you must:
1.Be a CF member
2.Order through our website http://www.dewitts.com
3.Use CFGP as part of your name in the order form, so we can ID them.
Each order will be automatically acknowledged WITHOUT the discount. Do not call or write to complain or question the non-discounted price. The system cannot adjust this, I will do it on our end and you will receive a corrected invoice. No Credit cards will be charged until the item is shipped.
1.Be a CF member
I am interested in the SP460, how difficult is it to install the threaded coupling into the radiator and install the fan control switch? I have a new DeWitts Radiator still in the box, I purchased a few months ago from one of your suppliers when it was on sale. thanks...Tom
I am interested in ordering the SP037 combination. Is it possible to get it painted black and an extra 3/8 npt bung installed? If so, how would I specify this when ordering on line?
Thanks & Regards,
Ron . . .
Thanks & Regards,
Ron . . .
Ron, Just order part# SP037 and order part # 333. #333 is our paint part number. There is a 3/8" bung in the radiator with the temp switch in it. If you need an extra one besides that you should call Christyn to make sure it gets ordered right. Thanks 517-548-0600
Former Vendor
The first thing you want to check is if the car has the 76 radiator, which they used on early 77's. The 76's used a curved upper neck and the 77's had a straight neck. If you have the later design (77-82) then you want the A77 radiator. You didn't mention if you wanted to go with fans or not but if so, check out the fan/combo.
Hello,
I just want to make sure I order the right radiator. I need a 69 smallblock, manual trans, with air conditioning and I'm not quite sure which one to order. I would also want it painted black which I see from the above response can be done. Thanks for the discount and help,
Jeremy
Jeremy
