DeWitts CF group purchase
Holley HP EFI w/TPI
Former Vendor
Hello,
I just want to make sure I order the right radiator. I need a 69 smallblock, manual trans, with air conditioning and I'm not quite sure which one to order. I would also want it painted black which I see from the above response can be done. Thanks for the discount and help,
Jeremy
Jeremy
Ok,Just ordered a radiator for my brother's car thanks for the dicount.I already have one in my car.It's been great,fits like the stock one, car runs perfect temp wise.One of the best if not the best companies I have dealt with.
Former Vendor
Can you ship to a border storage facility so that I can pick this up?
Hi John,
Will Dewitts ship a combination package to Sweet Grass, Montana with the free shipping offer? I actually live in Calgary, Alberta. Canada. but I find it is much easier and cheaper if I pickup my shipped parts from a border storage facility in Sweet Grass, Montana.
In addition, please confirm if the sale here is 15% off as I recall reading somewhere in Tom DeWitt's postings that the sale was only 10% off. Just want to make sure before I place my order on your website.
I will be ordering either a SP035 or SP037 depending on the configuration of my original radiator in my 1977 - L82.
Thank you in advance...
Don Yue
Don Yue
Sale ends October30th only! No exceptions
15% off any Direct Fit Radiator, Combination package or Spal fan.
Sale does NOT apply to Restoration Radiators
FREE SHIPPING! ($40-50 savings)
To qualify for the discount you must:
1.Be a CF member
2.Order through our website http://www.dewitts.com
3.Use CFGP as part of your name in the order form, so we can ID them.
Each order will be automatically acknowledged WITHOUT the discount. Do not call or write to complain or question the non-discounted price. The system cannot adjust this, I will do it on our end and you will receive a corrected invoice. No Credit cards will be charged until the item is shipped.
1.Be a CF member
I unpacked my radiator a couple of days ago.
Man...words don't do it justice, you guys really do beautiful work. If it works even half as good as it looks I'll be happy.
Former Vendor
Going to get the proper fit.
Hello Tom,
Thanks very much for your response. I will double check the upper inlet configuration on my existing 1977 - L82 radiator and make the order from your website for the proper combination package.
Thanks for the discount.
Don
Don
#33
Tom,
I just ordered the SP037 for my 80 4 speed, but I'm replacing the radiator support with an 82 support that I have. The SP037 should fit fine, correct? I believe the manual and auto radiator supports are the same. Thanks for the discount!
#34
got it thank you Dewitts for the very nice component that i will be installing shortly.
would however like to ask what alternator you would recomend to the dual spal setup? any other advise would also be apreciated. am planning on new cap, new hoses, new waterpump, new alternator and new paint under the hood. wow this job just grew a little.
doug
doug
#35
TOP SHELF in every way!
I installed mine 3 yrs. ago and it is perfect for my 3.70 geared 454 73' (as for as keeping cool in TX. heat ) I wish everyone had the quality control DeWitts have .
#36
Hi Tom,
I have a quick question for you, I ordered a SP037 (fan/rad kit) for my 1977 vette back in Oct. 2009 and I received it and everything is great. My quick question is this, if I decide to swap out my L-82 (350) for a new big block chevy (zz454 or larger) will I need to change to a big block rad or will the rad in the purchased kit still work with the big block? I haven't installed the kit yet, so if the big block rad is required then I may have to sell the small block rad that came with the kit and purchase a big block rad.
Don
Don
#37
Former Vendor
Hi Tom,
Don
Don
There is hardly any difference in size from the SB to BB rads. The cores used from 69 to 82 range from 26 to 27.5" so you really won't notice any difference when using an aluminum unit.
#38
Rad questions
Thanks again.
#39
Former Vendor
Sorry but I don't. The lower connection on a BB motor is 1 3/4 and the 77-82 is 1 1/2 so you'll have to come up with some kind of transition. You could send us your radiator and we could exchange it for a custom one with a 1 3/4 lower connection. With that setup, a 69-72 bb hose might fit.
