roller rockers and stock valve covers
Old 10-05-2009, 06:42 PM
tgensel
tgensel's Avatar
Default roller rockers and stock valve covers
Are there any roller rockers that will work under stock valve covers and a 72 350
Old 10-05-2009, 06:56 PM
LFZ
LFZ's Avatar
I have brought this question up a few times..it seems that some have clearance, and others don't. Some need the baffles trimmed, and others have just bolted the covers on and went. I would get a spacer and be done with it.
Old 10-06-2009, 07:10 AM
tgensel
tgensel's Avatar
anyone know a manufacture or model number
Old 10-06-2009, 11:08 AM
mysixtynine
mysixtynine's Avatar
Try these from jegs.
http://www.jegs.com/i/B%26amp%3BB/128/63900/10002/-1
about 1 inch taller. You will need two sets of gaskets and longer bolts.
Old 10-06-2009, 03:19 PM
tgensel
tgensel's Avatar
If i'm going with spacers I might as well give up on the oem look and get tall valve covers ! Sure would like to find roller rockers that fit if there is such a thing !
Old 10-06-2009, 03:22 PM
midyearvette
Support Corvetteforum!
midyearvette's Avatar
the comp cams roller tipped rockers should work with no other mods....good luck
Old 10-06-2009, 03:44 PM
JW3101
JW3101's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16-‘17-‘18
My '69 has the Comp Cam Roller Rockers with the original valve covers.
After blasting
Reinstalled
Old 10-06-2009, 06:23 PM
GUSTO14
GUSTO14's Avatar
Received 1,962 Likes on 1,283 Posts
This engine in my '73 uses Crane roller rockers with no problems. I did use double cork gaskets for some added clearance, but I don't know that I needed them.
This engine from my '63 turned 7,000 more than a few times with stock covers and no clearance issues back in the day...
It's now going back together with the same rockers and a set of slightly taller covers from PML...
Good luck... GUSTO
Old 10-06-2009, 08:36 PM
tgensel
tgensel's Avatar
will roller tip rockers net the same or close hp advantage as full roller rockers?
Old 10-06-2009, 08:59 PM
Brooklinite
Brooklinite's Avatar
Gusto, do your covers (in your '73) still have the drippers?
Old 10-06-2009, 09:52 PM
DRIVESHAFT
DRIVESHAFT's Avatar
On a stockish engine roller rockers are worth little to no horsepower anyway, so in that situation roller tips are just as good.
In more performance oriented builds the full roller rockers are better because the majority of the advantage of roller rockers is in the roller trunion, not the tip.
Old 10-06-2009, 10:04 PM
GUSTO14
GUSTO14's Avatar
Yes they do...
Good luck... GUSTO
Old 10-07-2009, 12:10 AM
Gale Banks 80'
Gale Banks 80''s Avatar
I had the Crower Stainless Rollers under my Stock Covers. I curently have Comp cams Stainless under Stock covers. 96 LT4's came with Crane Aluminum Rockers stock and less they used stock covers too!
Old 10-07-2009, 09:56 AM
Vette79C3
Vette79C3's Avatar
Roller-tipped rockers will fit under OEM Stock Valve Covers. Full Roller Rockers may not. I'm using full roller rockers with Aluminum Corvette Valve Covers. They are not tall covers but I am using double cork gasket to get some added clearance.
Old 10-07-2009, 11:45 AM
Lee H
Lee H's Avatar
I'm running a set of GM Performance 1.6 part number NAL-12370839 under stock covers.
Old 10-07-2009, 12:18 PM
TopGunn
TopGunn's Avatar
This is good info, I was told I had to use tall valve covers with my Comp Cams Roller Tips and I hate the things. They're so high, I had to extend the adjustments for the A/C compressor and it almost hits the hood. The alt. just clears them also. To change an Alt. belt I have to remove the valve cover. I'd say avoid the tall ones if you can. I never even tried the standards, just went with the tall ones.
Old 10-11-2009, 09:36 AM
surfertom
surfertom's Avatar
the spacers mentioned work great if installed properly. they do not take away from the stock apperance and will clear any roller rocker. my brother has then on his 69 Z-28 and i have them on my 69 vette. both of us have the lt-1 chevy valve covers. tom
To roller rockers and stock valve covers
Old 10-11-2009, 12:01 PM
682XLR8
682XLR8's Avatar
Running Summit brand aluminum rollers under stock aluminum covers, no problems
[IMG][/IMG]
Old 10-11-2009, 12:32 PM
c69vete
c69vete's Avatar
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
You can run these 1/4" thick spacers and gain 7/16" inside clearance and keep all of your standard brackets and valve covers with full rollers.
Old 10-12-2009, 07:50 AM
tgensel
tgensel's Avatar
Great info all.
I really am trying to have my cake and eat it too. Thats why I'm trying to stay stock but prepare the internals so that If I want, I can change Heads, intake, and exhaust and have the internals ready.
I want to do roller rockers first and I see lots of info but does anyone have a part # that works?
Quick Reply: roller rockers and stock valve covers
