Goodyear blue streak sportscar/scca specials
Looking for period correct tires to go on my superlite-gtr,s.
Has anyone checked out these tires.
Look on goodyears vintage racing page G-7,s
I work for a historic racing shop. We are required to use treaded racing tires for pre 67 race cars. They run either Goodyear or Avon
I have used them on my Vette for 2 events. Night & day. These things are like bear claws when warm. If you're doing a short Auto-X, the first few seconds they will be slick. But... Once warm, these things are STICKY! You'll have chunks of rubber all over the place.
not quite sure what size rim you're planning on putting them on. But, a 1972 (your avatar/name) they might stick out quite a bit. They barely fit under my 1980 without mods. My rims are 15x9. Just a heads-up.
Gkull recommended I use John Berget tires. I have used them & am plesantly surprised at speed & service.
what size rears do you use? I have 4 sets of 10X27X15 hoosiers from JB racing. I'm done racing my Vette. I'm selling and or should say have sold nearly everything not being used to clear out my garage. i'm keeping my 12X27 rears and wheels in case I go drag racing.
gkull,
any comment on using the goodyear's on the street? I know they are not DOT rated and the Avon's are, but I wondered if that might just be because they didn't go through DOT testing..
i see mixed opinions online about using them on the street.. many say no issues - that they've done it for years and others say the sidewalls are too thin because the tire is constructed lighter..
i like the letterwall look, but may have to settle for Avon's (CR6ZZ)..
gkull,
Very simple answer - Racing tires are only sticky at tire temps of over 170 degrees and even better as they near 190+ Below that they are like grease. Any water or cold pavement and they are down right dangerous.
Todays Kumho MX and other street Ultra performance tires are better than racing slicks of just 10-15 years ago
gkull,
Go over to one of the Cobra kit car forums (http://www.ffcobra.com/)and ask over there, as the G-7/G-19's are very popular over there.
I personally love the look of them and I think that if you where using them as weekend show/occasional motorsport event car, then I would go for it. For a daily driver their soft compound and questionalble wet weather grip would put me off.
Nick
Nick
I use the Avon cr6zz 245/60/15 on my 69 427 L88 motor. Love them. they stick enough also cold,when they get warm...
you don't get much debris in normal use. they should last many miles on the street and don't suffer of heat cycles like other racing tires. I think these Avon's should be the standard tire on any powerful vette on stock rims.expensive
here is my old post about
http://forums.corvetteforum.com/c3-t...von-cr6zz.html
