on the subject of paint
Is there a simple way to tell what kind of paint is on your car?
One stage or two? This white on our 'vette looks good until you're right on top of it (or under street lighting) and then you see the infinite chris-cross scratches all over. I cannot figure what could make that much scratching that is not through the paint? Oh, and I am sure this is not the original paint.
I'm not afraid of color sanding or power compounding polishing, my Caddy had terrible looking paint but it's a lacquer paint. After wet-sanding and compounding it was perfect! I know that wet-sanding will look milky white while sanding clear coating and after that you are into the paint. Any Tips?
Former Vendor
Unfortunately it is hard to say when you are dealing with white. Any other color it is easy to identify...but white is a hit or miss when sanding on it and trying to identify if it has clear on it or not due to the residue is milky white when clear is sanded....like you mentioned My only advice is to be careful while buffing and such so you do not break through and have another issue other than scratches. I hate having to buff/polish over someone elses paint job...I never know wether they applied enough paint or if they were cheap and stopped when the color was consistant.
"DUB"
"DUB"
Those scratches that you are refurring to is called crows feet or laquer checking. There is no way to really fix that by buffing. It is where the paint has shrunk over time creating the cracked look. A new paint job is in order.
That'll work as long as there is alot of "cleaner" (really compound) in the wax.
